Mitsubishi WS-65511 65 in. Rear Projection Television
Problem for Mitsubishi WS-65511 65 in. Rear Projection Television
The timer light keeps flashing but the tv wont
By rebekahlyn19 on Nov 10, 2009
the timer light keeps flashing but the tv wont come on
Best Solution
posted on Nov 17, 2009
Very Helpful)
goldthwaite
Rank: Apprentice
Rating: 100%, 1 votes
I followed these instructions from SD Tech on my Mitsubishi WS-65511. After I believe a power outage hit my house while sleeping, my TV wouldn't power on. The green timer light would flash for about 60 seconds and neither the remote nor the power button would turn the TV on. I took the front panel off as well as the keyboard and unplugged the wires going to the power and reset buttons. Then plugged the TV back in and using the remote the TV powered on normally. I plugged the power/reset wires back in and tried it again and it still didn't work. So I unplugged the wires and put the rest of the keyboard/panel back together and the TV works just fine, but only with the remote.
Thanks SD Tech.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Nov 10, 2009
Very Helpful)
SD Tech
Rank: Guru  Televisions & Videos  Expert
Rating: 97%, 1290 votes
ONLY 1 of 2 things can cause this problem----
First thing to do is remove front speaker grill--it should pull out and is secured with plastic pegs--behind it you will find an inspection plate---
Notice the one or two pairs of wires coming from the front keyboard of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different sizes so you cannot get them wrong)
The idea here is to remove the front keyboard with its reset button etc from the circuit---You will still be able to try to turn the set on with the remote---
These sets have a Receiver that is called a DM board--(large metal box to the left as you look from the back) and if the power goes out the green light will blink for about 70 seconds and then go out---it is the Receiver booting up. It is called the DM board.
If disconnecting the keyboard allows the set to turn on--you have a bad reset switch and two choices---either operate the set only with the remote or to remove the front screen and get at the reset switch (it is tiny) and remove and/or replace it.
If disconnecting the keyboard does not restore the set to operation---the receiver is bad---there are 4 or more caps and some pico fuses that can fail in that unit---Mitsubishi no longer sells or repairs these--if it is bad and not the caps there is a company you can send the unit to and have it repaired--if you need to know their name let me know---
You can call them and get a quote for repairing the receiver. There are also sites on the internet selling a kit for this repair.
If this information has helped you rate this solution as I do this here for free.
Let me know what more information you need--I am here to help.
SD TECH
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Mitsubishi WS-65511 65 in.
Questions and Unsolved Problems for Mitsubishi WS-65511 65 in.
Do you recommend Mitsubishi WS-65511 65 in. Rear Projection Television?
Answer
Answer
when the power button is pressed the green light turns solid but the screen is black. The green... (More)
Answer
I have a red shadow on the right side of my screen. I tried to adjust the Convergence but the lines... (More)
Answer
Power does not come on for more than 2 seconds when power button is mashed.
Answer
I have the TV, this looks like cars I have the tv no remote. I cant seem to get it to recive a... (More)
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in New York, NY
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Your name:
Your email:
Your friends email addresses: (e.g. Julie@email.com)
(Separate email adresses with commas)
Message:
Cancel
