Power up the pc and see if the fans are working. If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Was this helpful?
Yes
No
Popular Solutions for Dell Dimension 4600 PC Desktop
can't get vedio to paly that i recived in email say i need flash play plugin I have flash play 10. I...
(More)
can't get vedio to paly that i recived in email say i need flash play plugin I have flash play 10. I don't know what to do.
Dell Inspiron 8200 won't boot after installing new (actual refurbished) motherboard. Power light...
(More)
Dell Inspiron 8200 won't boot after installing new (actual refurbished) motherboard. Power light comes on. Hard disk light comes on but immediately goes off. Power light goes off after about 5 seconds.
I cant get my Toshiba Equium to work off the mains. I have had it on charge over night to try and...
(More)
I cant get my Toshiba Equium to work off the mains. I have had it on charge over night to try and boost the battery but it went into hiberate and wont restart or work. Is there a switch that I have turned off by accident under the laptop?
