Dyson DC07 Bagless Upright Cyclonic Vacuum
Problem for Dyson DC07 Bagless Upright Cyclonic Vacuum
DC 07 beater bar won't turn when on carpet
By bubs448 on Nov 09, 2009
DC 07 beater bar won't turn when on carpet setting. Filter has been washed.
Solution #1
posted on Nov 10, 2009
Not Rated)
Vac Belts
Rank: Wiz  Vacuums  Expert
Rating: 80%, 78 votes
The belt(s) need to be replaced periodically. If the belt is worn, stretched or broken it will not pick up the way it should. You can get DC07 replacement belts here:
Replacement belts for DC07 w/ clutch system
Replacement belts for DC07 w/out clutch system
Was this helpful?
Yes
No
Popular Solutions for Dyson DC07 Bagless Upright
Questions and Unsolved Problems for Dyson DC07 Bagless Upright
Do you recommend Dyson DC07 Bagless Upright Cyclonic Vacuum?
Answer
Answer
My DCO7 Dyson is completely blocked. It has little to no suction. How do I fix that?
Answer
Dyson DC07. Problem:- switch the hoover on and it cuts out after approximately 1 second. Any ideas... (More)
Answer
Dyson DC7. Problem:- switch the hoover on and it cuts out after approximately 1 second. Any ideas... (More)
Answer
roller brush stops spinning and vacuum makes noise. Brush will spin normally ok, until you use it on... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dyson DC07 Bagless Upright...:
Top Vacuum Experts
Rank: Guru Guru
Solutions: 1220
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Vacuum Experts
Top Vacuum Repair
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
