No it is done purposefully in the animation to keep the children's attention, bright colours and all that. You can check by showing a 4k DVD or loading a Pantone Image via the USB port.
It is possible that there is a allergy that is growing the blue and green gun, it will not grow in the red gun, and it blocks the video and makes it look dark, on the greenish side. To fix the problem, you have to change the coolant in the guns, and then it will look like new again.
Depending upon the signal, perhaps the convergence is off all the time, just not seen. If you can solder, try resoldering the convergence IC pins. Let me know if there is any change.
I tried the solution that was posted for this problem and it worked!
Just remove the Low front panel by removing the two bottom screws that are covered by two screw covers, then remove the second panel (black) by removing the 4 screws then you'll notice a module with 6 adjustment knobs, get a small screw driver, and with the t.v. on, being carefull , and with somebody accross the room looking at the screen begin with the lower left knob and turn left very slowly and ask the person across the room to let you know if the screen is better or not, after this I had to adjust the green as well so, I adjusted the next knob over to the left. Do this adjustment carefully and try to remenber the original position of the knobs in case you have to go back.f
Good Luck,
Californian.
Hi
I just bought a 42pc5d plasma tv it's an LG I bought it in Sept. 07 it started doing the exact same thing your talking about here the red glow type thing. Luckily for me and I hope in your case that the tv is under warranty, although if you know someone or even a repair place I don't think it would cost much to fix (just a guess but the guy told me that it was an easy fix so don't let them try to screw you). It really is a simple fix according to the tech. You need to adjust the voltage. He took the tv and watched it until he saw the red and adjusted the voltage and I had my tv back the next day. This was about a week ago and I haven't seen it since. I hope this helps and I hope you have a warranty. By the way LG comes with a 2 year manufacturer's warranty standard so if you didn't get an extended warranty from where you bought it if it's less than 2 years old call LG and they will arrange to have it fixed that's what I did. Here's the number 1-888-542-2623. Good luck.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html ·http://esupport.sony.com/perl/news-item.pl?news_id=24 ·Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
