Heaters
Problem for Heaters
Generic problem for all Heaters
Green light beeps 5 times,c5 error, any qui...
By ickeysavage on Nov 09, 2009
green light beeps 5 times,c5 error, any quick answer to fix this ?LG multi type room, 4 mths out of warranty!!
Solution #1
posted on Nov 10, 2009
Not Rated)
mac5932002
Rank: Guru  Air Conditioners  Expert
Rating: 88%, 55 votes
this is a communiction error between the indoor and outdoor units, may be as simple as a loose connection or could be a board failure. these units can be quite complicated. may want to call service company
Was this helpful?
Yes
No
Popular Solutions for Heaters
Questions and Unsolved Problems for Heaters
Answer
What is the best portable heater for a 700 sq ft area
Answer
how can you buy things for less than what they ask for?
Answer
electric fireplace power switch not working.Need to replace.
Answer
Forced air Furnace operates normally to start, flame ok, then main circulating fan stays on... (More)
Answer
I just bought a Lennar home in the Hanford area. It was a foreclosure. There is a Heat n Glo... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Heaters:
Top Heater Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Heater Experts
Top Heater Repair
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
