Question about Xerox Phaser 8500N Printer
Error message have  an error message 04,021,42:7924 09,037,45:7924
I have a techtronic xerox 8200 printer. it keep coming up with a message of "Load cleaning sheet" but the paper tray has been loaded.
What do I need to do to sort this problem???
Posted on Sep 23, 2008
    President:
  • 2,072 Answers
9,037.45 Yellow Ink Stick Count Fault
your 04,021.42 here are the possibilities.
error message - arrwup.gifPrimary Causes The troubleshooting table lists parts and wiring referenced in the troubleshooting procedure.
Table 1. 4,0xx.4x Troubleshooting Reference Table Applicable Parts
Wiring and Plug/Jack References
Electronics Module, PL 5.0
Right Side Wire Routing (2/2), Figure 3
Printhead, PL 2.0
Electronics Module, Figure 6
Drum Assembly, PL 2.0
Electronics Module Power, Figure 7
Drum Heater Relay Board, PL 5.0
Right Side Wire Routing (1/2), Figure 2
Drum Temperature Sensor, PL 6.0
I/O Board (2/2), Figure 10
Troubleshooting Procedure Table 2. Process Control Error Troubleshooting Procedure Step
Questions or Actions
Yes
No
Test the heaters.
Run the Service Diagnostics Monitor Heaters tests with all heaters On.
Do the heaters function properly?
Replace the Electronics Module ( REP 5.0.5).
Go to Step 3.
Check the harness to the failed heater.
Is the harness damaged?
Replace the harness.
Replace the failed component.
Posted on Jan 07, 2008
Dcz625 has error 6
Q3 ERROR CODES - WHAT DO THEY MEAN? A3 Error 1.Battery inside CD Changer needs to be replaced.
Error 2.CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3.CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4.Connection problem. Reconnect the data cable.
Error 5.CD error message. Could not read correct data due to CD ROM.
Error 6.CD error message. Could not read data from disc because it is upside-down.
Error 8.Tape Drive system defective. Eating tape or something wrong with the drive system.
Error 9.Weak RF. Try alternate frequency
NO CD.CD error message. No CD is magazine or no magazine in CD Changer.
Clarion DCZ625 Owner Manual
Good luck.
Semper Fi,
Z
Feb 20, 2018 | Office Equipment & Supplies
My oce fx 2081 trouble code 05 help me pleas
OCE clear error message replace toner oce fx 2081 ... - Fixya
www.fixya.com/tags/clear_error_message_replace...oce_fx_2081/.../oce
Ask your Clear error message replace toner OCE fx 2081 questions. ... ...error code0501 message, though we've vacuumed it the toner as best as possible. ... ...error 2201 switch on/off messages very frequently on my oce 9400 machine, any solution!!! thanks Might be NTC6, which is located in ... 05 is appearing on the.
clear error message replace toner oce fx 2081 Questions ...
www.fixya.com > Forum > Tags
Find solutions to your clear error message replace toner oce fx 2081 question. ... ...error code 0501 message, though we've vacuumed it the toner as best as possible. Well ... ...error 2201 switch on/off messages very frequently on my oce 9400 ...
Sharp ARM 550/620/700 Reset Machine with Error Code ...
Dec 15, 2015 | Office Equipment & Supplies
Precor error 3
Precor Error 03, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicates an upper PCA problem when it is consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 03 E03 EEPROM Test Error
Feb 22, 2014 | Precor Exercise & Fitness
Error 45 on opening e mail, solution
Problem loading message: Error Code 45If you received an error code 45 when attempting to load a message, you'll need to contact us to resolve this error.
To contact Yahoo about receiving an error code 45 message:
  1. Select Contact Customer Care on this page to go to the help form.
  2. In the form, select:
    1. Your version of Yahoo Mail
    2. Category: Notices and errors
    3. Sub-category: Received temporary error code
  3. Provide these details for at least one message that produced this error:
    • Contact name and email address
    • Date message was received
    • Message subject line
    • The folder containing the email (Inbox, Spam, etc.)
    • How you attempted to open the message when the error displayed (from a folder, from email search results, etc.)
Sep 05, 2013 | Yahoo Mail
Error code 1 and 3 on my Precor 9.21s treadmill?
Precor Error 01, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 01
Mar 27, 2013 | Precor 9.21s Treadmill Display Console...
HOW TO FIX CAMERA FAILED ERROR MESSAGE.HANDLER.HANDLE MESSAGE(-1)
ERROR HANDLER.HANDLE MESSAGE(-1)...CAMERA GALAXY YOUNG......!
Sep 12, 2012 | Samsung Galaxy Y
Minolta 2200 service code 16
(TABP0902037EN00) - magicolor 2200 DeskLaser - What are the steps to fix a service call 16H transfer belt rotate error on a magicolor 2200 series? (TAUS0805552EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'ACC_Getstatusr EC;Code=__D, Resetting ACC to Initial State' (q0601101) (TAUS0805008EN00) - magicolor 2 + - Installing CrownNet code on the Crown monochrome printer (q0499042) (TAUS0803976EN00) - magicolor 2200 + - Flashing System Code to DeskLaser to Correct 'Starting System Firmware Image' Message (q0202107) (TAUS0806277EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Missing' (q0800700) (TAUS0806280EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Missing' (q0800703) (TAUS0806281EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Fuser Missing (q0800704) (TAUS0806282EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Missing' (q0800705) (TAUS0806283EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Low' (q0800706) (TAUS0806284EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Empty' (q0800707) (TAUS0806286EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Fuser Unit' (q0800709) (TAUS0806287EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Life Low' (q0800710) (TAUS0806288EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Transfer Belt' (q0800711) (TAUS0806289EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'OPC Drum Life Low' (q0800712) (TAUS0806290EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace OPC Drum' (q0800713) (TAUS0806292EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Waste Toner' (q0800715) (TAUS0806293EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Life Low' (q0800716) (TAUS0806294EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Oil Roller' (q0800717) (TAUS0806295EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Input Tray' (q0800719) (TAUS0806296EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Upper Bin' (q0800720)
Dec 11, 2010 | Minolta magicolor 2200 DeskLaser Printer
Could not create this file.Shall I try again?
Click Start
Click Run
Type CMD and press ENTER.
Enter CD \ and press ENTER.
Enter CD "program files" and press ENTER.
Do you get an error-message?
If not, that's good. If so, what's the error-message?
Enter CD "PrintMaster 2.0 Gold" and press ENTER.
Enter CD "Components" and press ENTER.
Enter CD "Clip Art" and press ENTER.
Enter CD "Travel" and press ENTER.
Enter CD "Europe" and press ENTER.
Enter ECHO Y > "Rusty Fence.jpg" and press ENTER.
Jan 04, 2010 | Encore Computers & Internet
Editing text
Windows
» HP Scanjet Scanners Supported and not Supported in Microsoft(R) Windows XP s.gif » Resolving 'Missing MSIEXEC.EXE File is Linked to Missing Export: MSI.DLL.222' Error Message During Installation of the HP Director Software s.gif » Resolving 'Scanner not supported' or 'Unsupported operating system' Error Messages s.gif » Resolving Image Zone Install Error 1402, 1406, 1714, 1904, 1935, 2203, or Unknown Error s.gif » Error 'The System Cannot Find the File Specified' While Attempting to Install the HP Photo & Imaging Software in Windows 98, 98se, or Me s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Error Install Failure' Message for the hpznfx01.exe Software Module Displays on the Computer When Installing HP Image Zone s.gif » The message 'Fatal error during installation' or 'Error Install Failure' Occurs When Installing HP Image Zone s.gif » A 'Fatal Error' or 'Error_Install_Failure' Error Message Displays on the Computer When Installing the Image Zone Software s.gif » The Error Message 'Error_Install_Failure' or 'Fatal Error' Occurs when Installing Image Zone Software s.gif s.gif
Macintosh
» Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Scanner could not be initialized' Message Displays in Mac OS X when the All-in-One Software is Installed s.gif » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif s.gifs.gif
Jun 13, 2008 | HP 4570C Flatbed Scanner
Xerox Phaser 8500N Printer Logo
512 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
