My rear projection mitsubishi big screen tv has a problem with the red light. Anything that is red shows up below where it should be. We tried reconfiguring but it would not move. Do I just need a new red bulb or do I need to have it repaired by someone?
I have a Mitsubishi Model- WS-55511 projection TV. The picture is really jiggling until I opened the...
(More)
I have a Mitsubishi Model- WS-55511 projection TV. The picture is really jiggling until I opened the back and put something over the Green projection light blub(it stopped when I did that, but picture dark). Will a new Green light bulb fix the problem or do I have more problems?
I have a Mitisubishi rear projection tv. When I turn the power on, the power will go off in just 2...
(More)
I have a Mitisubishi rear projection tv. When I turn the power on, the power will go off in just 2 or 3 seconds. I troubleshot the TV using the DEVICE - MENU button push and go a 2-3 flash response, which is a deflection circuit problem. Is this something I can fix myself? Thanks.
I have a WS-55511; the TV will try to turn on the green light stays on for 1 or 2 seconds. You hear...
(More)
I have a WS-55511; the TV will try to turn on the green light stays on for 1 or 2 seconds. You hear a single click and then it turns on then off. When I pull the error code I am getting a 1 then a 2 which I believe = no error. Please Help, thanks Scott
