Gaggia Evolution Espresso Machine
Problem for Gaggia Evolution Espresso Machine
My Gaggia evolution espresso machine basically
By nancyresnick on Nov 09, 2009
My Gaggia evolution espresso machine basically stopped working because water comes out so slowly that it would take an hour to make an espresso. I tried to take off the unit where the water comes out using allen wrenches but then did not know what to do. Please help! Thanks!!
Solution #1
posted on Nov 12, 2009
Not Helpful)
EsWorld
Rank: Guru  Kitchen Appliances  Expert
Rating: 86%, 331 votes
After you remove that there is a spring and plastic valve, check that use pic fro reference.
Was this helpful?
Yes
No
Popular Solutions for Gaggia Evolution Espresso
Questions and Unsolved Problems for Gaggia Evolution Espresso
Do you recommend Gaggia Evolution Espresso Machine?
Answer
Answer
apparent low pump pressure on gaggia evolution.Even if I do not tamp the coffee when the brew switch... (More)
Answer
my gaggia evolution espresso is not working. I tried de scaling but the water does not run through... (More)
Answer
I have a Gaggia Evolution and haven't used it for a long time. Now, that I use it again, when start... (More)
Answer
My gaggia evolution leaks water while making coffee .It appears to be coming from inside the machine... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Gaggia Evolution Espresso...:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 2511
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
