Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
That is usually the evaporator fan motor ($30).
Check to be sure you can get a replacement fan first, they last about 4 - 5
years. Available from a parts supplier or electric motor company.
Unplug fridge. Located usually in top of freezer behind a vented cover
plate. Remove cover, remove screws holding fan in, may have to cut wires.
Replace with new motor, make sure the fan spins the same direction (CW OR CCW)
as your old one, if you don't know which way it should spin then be sure it
pushes air into the freezer area and doesn't spin backward drawing air from the
freezer area..
Was this helpful?
Yes
No
Popular Solutions for Jenn-Air JCD2389G Side by Side
Changed filter 2 weeks ago and now the "Change Filter" light has come on. How do we shut...
(More)
Changed filter 2 weeks ago and now the "Change Filter" light has come on. How do we shut off the light?
i need to replace the defrost timer in a jenn-air side-by-side and can't figure out how to get...
(More)
i need to replace the defrost timer in a jenn-air side-by-side and can't figure out how to get access to the connector
We have a Jenn-Air side by side Ref/Frez it is working fine but water runs from under the unit. It...
(More)
We have a Jenn-Air side by side Ref/Frez it is working fine but water runs from under the unit. It is in the garage so not a major problem. Model #JCD2389GE
