Question about JBL PB12 Subwoofer
"Dhoom" sound from subwoofer
My subwoofer used to work perfectly, but after I unplugged the power once without turning the unit off, it stopped working. Even after giving the LFE input from my Harmon Kardon receiver, the light remains red. Plus, it makes loud "Dhoom" sounds intermittently when power is on.
  • burn_junk Nov 15, 2008
    I have the exact same Issue with mine. Did you find a repair, circuit schematics or parts list??
  • glroberts84 Jan 20, 2009
    Any solutions to this problem? I have the same one...
5 Suggested Answers
SOURCE: Infinity PS-12 Subwoofer clicking in and out of standby
I've got the same problem with my PS-10 from Infinity. It works great for about 30-45 minutes, then click in and out of standby mode. It sounds to me like a overheating safety fault. When I take off the amp panel (unplugged), it feels quite warm, and you can see that there is really no way for heat the escape. I tried running it briefly with the amp panel outside and it seemed to work fine! Since I'm out of warranty, I think I'll try cutting some ventilation holes. I noted there are 2 oval shaped holes near the bottom (just above amp), but covered with the panel sticker. I'll try cutting those open first.
Posted on Dec 19, 2009
  • 308 Answers
SOURCE: JBL Subwoofer - Intermittent operation
Sometimes bad caps show a lifting or rounding of the top of the cap, sometimes this top will split from heat and pressure and sometimes it will not show any sign of damage but will be dry inside and its capacitance value will drop to a very low value. Replace the big power supply caps and test again. Get the same size, value and voltage rating. You can go higher on voltage rating and a bit on value. Getting a similar size or something that will fit in the same space is important also.
Posted on Mar 24, 2010
  • 14 Answers
SOURCE: The subwoofer stops working and makes a loud flat
One year waranty period from JBL on the electronics.
To find the authorized JBL service center in your area:
  • Go to: www.jbl.com
  • Click on United States
  • Click on Support at the top
  • Click on Find My Product
  • Enter your Model Number or Select your Product from the drop down list; then SUBMIT or SEARCH
  • On the list on the left side, click on Service Center
  • Supply your zip code at the next screen, then FIND
  • A list of service centers in your area will come up.
Posted on Nov 23, 2010
SOURCE: I have a JBL venue sub10 subwoofer. I noticed a
Hi well i would think that perhaps a capacitor in a cross-over network may have failed? What top do is open up the speakers and locate the capacitor, and inductor, cross-over network, that's the part that splits the frequencies to each speaker, hi, mid, bass, and simply replace the capacitor "On Spec" as it were, this or simply replace the entire cross-over network? this may help. It's worth a shot anyway? It also may simply be a bad speaker? again replace "on spec".I don't think from what you describe that you have "Overlooked" anything at all, it's just bad luck.
"on spec' simply means to replace without thinking about it....
Posted on Sep 26, 2011
Stopped working. Power light is on. Could it be a fuse? Can I change it myself? Is there a lifetime warranty?
Amp has power, but no sound! - ecoustics.com
www.ecoustics.com > ... > Archive through November 13, 2007 Forum
Nov 5, 2007 - The other night my fiance's amp stopped pushing the subwoofers. ....also, it was working fine for however long- and then just stopped working. if that were the case, it wouldn't have worked in the first place. .... lastly before u go saying but the amps power lights on i'm sure the amps ..... Car Speakers Forum WHY DOES MY AMP POWER LIGHT TURNE RED ON PROTECT ...
Sep 11, 2011
Please someone help me! I am dying without my music!!!
Aug 4, 2011
Subwoofer stopped working all the sudden
May 26, 2010
More results from www.ecoustics.com
Jan 18, 2016 | Audio Players & Recorders
Humming sound in subwoofer after it's been playing for a while
It sounds like you are describing an earth loop problem. I won't go into detail in this post, but try an isolation test first. disconnect everything from the reciever except the sub and try connecting say a BATTERY powered mp3 player or cd player to minimise connections to the electrical mains earth. you could also isolate things by taking your sub to a friend's house and trying it on their system.
If it is an earth loop use a process of elimination to find out which two pieces of equipment causes the earth loop. then apply filtering.
you can buy earth loop isolation transformers for about AU$26 and I've used one on my sub myself. Theyhave RCA (phono)plugs on each end and they connect inline with the signal cable to the sub amp.
as for the thumping sound it might be the speaker protection circuitry cutting off the amp to protect the subwoofer speaker from damaged. This might be triggered if the earth loop sound is causing the sub amp to overload and clip.
Failing this there might be a dried out overheated electro capacitor in the amp circuit causing the hum. Hav a chat to your local electronics person, who should be able to spot it!
Hope this puts you on the right track
Happy Hunting!
Jan 07, 2010 | Sunfire Audio Players & Recorders
I have an alpine MRP-500 amp that used to work great with my 2 10" Type-R subwoofers. Out of nowhere the sound just stopped working and still will not. I had the amp and subs tested and the guy said it was...
  • make sure the subwoofer level is up on the head unit.
  • Make sure the RCA cables are good.
  • Make sure the remote wire is connected and has 12v+ when the head unit is on.
If the remote wire is not turning on the amp, its not going to work. To hot wire it to see if thats the problem, just run 12v+ to the remote jack. That will turn on the amp.
Nov 22, 2009 | Alpine MRP-M500 Car Audio Amplifier
Loud buzzing from Kef PSW1000 Subwoofer
yes. A good idea. Kill power to the sub, then unplug and remove everything from the sub. go ahead and plug it in again and check for buzzzz.
That is test one. if you have buzz still, its the sub assembly. bad luck, but not impossible. If the buzz is gone its one of the signals to the sub. They can produce a buzzz without any signal coming from your stereo equipment. Replace the feed line, enjoy! BTW...Kef sure does sound clean. good choice.
Nov 09, 2009 | KEF Audio PSW 1000 Subwoofer
JBL subwoofer PSW-D115
Hi Im a Certified Repair technician, I seen few problems with this unit, there is a amplifier module inside this unit, is really hard to find since JBL discontinued this almost immediately.
Sorry no really worth to bother........
Apr 10, 2009 | JBL PSW-D112 Speaker
No sound
1. Verify unit is plugged in and power outlet used is active.
2. Is power switch on?
3. Is auto turn on/off set properly?
4. Is unit receiving an input signal from your source?
5. Have all controls on subwoofer (volume, crossover, phase, etc.) been
properly set?
6. If unit has been running at high levels, one of the protection circuits may be engaged.
7. Has the built-in amplifier overheated?
http://www.velodyne.com/products/manuals/DLS.pdf
Mar 22, 2009 | Velodyne DLS-3500 Subwoofer
Stopped working. I-trigue 3400
The stereo -jackbus is broken if your speakers won't work and your headphones are fine. The stereo jackplug holds a little switch at the back, which moves sideways if you connect headphones.
Solution is very carefully opening back end of stereo connector bus and reassembling the switch
Oct 24, 2008 | Creative Labs ITrigue 3400 2.1 Speaker...
Acoustimass Subwoofer has a low "hummm" sound when turned on.
Sounds like an inadequate ground wire in the signal cable. You may have to replace the cable between the reciever and bass module. It also, however, may be IN the bass or reciever module.
Aug 04, 2008 | Bose Acoustimass 15 System
Sony Active Subwoofer noise
The circuit that should be turning the sub on and off based upon the presence of an audio signal is not working correctly and the sub is trying to reproduce 60 cycle hum. The unit needs service.
Dan
Mar 09, 2008 | Audio Players & Recorders
Subwoofer not powering up
I could either be the sub or the main unit. The main unit actually sends a signal to the sub to turn it on so if that circuit is bad in the main unit the sub is never going to come on. I've also seen bad cables (You'd be amazed at how stubborn people can be when din connectors don't cooperate).
Sep 10, 2006 | JVC TH-M505 System
JBL PB12 Subwoofer Logo
94 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
