Maytag M6D24E7A Air Conditioner
Problem for Maytag M6D24E7A Air Conditioner
Cooles but will not heat
By fritz9537 on Nov 09, 2009
cooles but will not heat
Solution #1
posted on Nov 11, 2009
Not Rated)
drberry
Rank: Guru
Rating: 92%, 82 votes
heat strip is possibly burnt out and will need to be replaced. The strip sits inside the unit right behind the evaporator coil, To access the heat strip you will need to remove the unit from its casing and place it on a level surface.. The heat strip is possibly in a metal casing and the heat strips look like the heat strips in a toaster. The assembly comes out by removal of a few phillips head screws and has an electrical disconnect plug that powers the coil. Take the coil assembly along with the model and serial number to the nearest appliance parts house for replacement part. Good Luck hope this helped you somewhat
Dave
Was this helpful?
Yes
No
Popular Solutions for Maytag M6D24E7A Air
Questions and Unsolved Problems for Maytag M6D24E7A Air
Do you recommend Maytag M6D24E7A Air Conditioner?
Answer
Answer
if i shut it off and the start it up again.... the cool light is solid but after some time it starts... (More)
Answer
The lights come on and it makes some noise but there's no air flow. The fan doesn't turn on. I think... (More)
Answer
seems all functions are working but the fan ..then 30 seconds the setting switches to low fan, then... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Maytag M6D24E7A Air...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
