Refrigerators
Problem for GE Refrigerators
Generic problem for all GE Refrigerators
Stubborn Monogram ZISW36DYA Not cooling pro...
By erich_zim on Nov 09, 2009
To any GE Factory Tech or GE Experienced Tech: I have replaced a filter/dryer on a Monogram Refrig Model Number ZISW36DYA. It appeared to work fine when checked after 3 days...and again after 2 weeks so I never checked again. Three months later customer comes back to a non- working refrigerator and calls our shop.
I went out to find the system again in 20 in. Vacuum with Freezer temp at about 57 and refrigerator compartment closer to 78 and suspected another restriction further down the capillary tube. I called GE service help to find out if this refrigerator could have the heat exchanger replaced from the front opening. This unit is built in and through some lousy planning can NOT be removed without major remodeling that would run in the thousands. The tech at GE said the heat exchanger MUST be replaced from rear by pulling unit forward. I explained this to customer and left to await his decision to come.
It's now 2 weeks later and customer sent me a nasty letter berating me for incompetence because he had GE factory service out and they replaced the defrost timer with no defrost necessary. He also claimed that ALL the work on this unit could be done from the front.
I have several questions. 1. How can a bad defrost timer, with no defrost necessary give a reading of 20 in. vacuum on the suction side of this machine? 2. Can ALL the parts of the refrigeration system be replaced from the front opening of this machine? 3. Is it possible that the temperatures could be that high while pressure is 20 in Vacuum and the problem be a faulty Defrost timer.
Any help would be greatly appreciated. I Have been doing this for 30 years and have NEVER heard of such a combination of High temps, high vacuum caused by a defrost problem.
Confused Tech
Clarification Request
Posted by jumptrout51 on Nov 09, 2009
What was the high side pressure reading at this point in time? Sounds like a common restriction to me. If the fridge was left off,then plugged back in a day or 2 later the restriction could have moved with pressure equalization,then gotten trapped in the filter drier. It has absolutely nothing to do with a defrost timer.
Popular Solutions for Refrigerators
Questions and Unsolved Problems for Refrigerators
Answer
the samsung four door quattro refrigerator
Answer
Amana side by side frig 85127
Answer
I think my compressor is going keeps clicking and buzzing and ice cream melting. Does this just... (More)
Answer
water not coming out, but ice maker is working and dispensing ice
Answer
it keeps making this loud long winding/ringing sound every 2 minutes or so. Now things are not... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE Refrigerators:
Top Refrigerator Experts
Rank: Wiz Wiz
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
GE
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
