Question about Sony Cyber-shot DSC-N2 Digital Camera
The LCD touch screen is not lit. Sometimes camera does not turn on. It got wet in a heavy thunderstorm.
    New Friend:
  • 8 Answers
It's probably fried by the water. Your only hope is to set it aside for a couple weeks, and let it thoroughly dry out, then try it again. But probably you already tried to turn this one on while it was still wet, and that fried the circuitry. If so, you're outta luck. Sorry! Next time something electronic gets wet, do that but don't EVER try to turn it on while it's still wet.Gotta give it LOTS of time to dry out inside in order to have any hope of a recovery.
Posted on Nov 10, 2009
Testimonial: "Even though bad news for the device, good advice for the replacement. Thanks"
SOURCE:
Power turns but screen stays black no
Sounds like you need a new LCD Screen(is the screen a little lit up or completely blank) If completely blank than most likely the LCD needs to be replaced if it appears to be slightly lit up than most likely it is a software related issue.
Mar 31, 2014 | HTC Cell Phones
My RTI m2(?) fell off the table to the floor. The black cover dislodged and the screen also dislodged. It was still lit. When I replaced the screen the icons were lit with a pink band across the bottom of...
Sorry this remote can't be repair it is garbage,because the small display LCD screen panel it have mircro cracks and fractures in them and leaking chemicals radiation that why u able pink chemicals band across the the small display LCD screen panel.It time to buy another remote.
Sep 06, 2011 | Rti Technologies Rti T1 Remote Control
My Gigaware HD 1080p 3" Touch screen Camera wont
Looks like your screen flat wire connector is loose and worse it is torn.Replace it.
Oct 27, 2010 | Haier D36FT 1080p HD Camcorder with 3Inch...
32 inch lcd tv wont power on,replaced power board and still dead.
If the failure was due to some heavy voltage crisis or thunderstorm then it may sometimes go beyond the scope of our forum but not to worrry you must be familiar to test voltage of +B, sub voltages , the power to the processor, check for shorts, look out for burnt components..... overall check carefully with a flow chart elimination... attempt only if familiar or else take help with these views for an estimation.. ask for the exact fault and check for the replaced item.... hope you get this right.
Jul 01, 2010 | Emerson LC320EM9 32 in. LCD HDTV
The lcd screen is lit up but none of the touch screen works so i can't access the menu, yet i can still record, but on playback i can't press play rewind etc
touch screen deactivated? checked manual?
to activate you have to put her in play back mode by moving that switch
so please read some basic instruction or let somebody demo it to you :-)
May 26, 2010 | Sony HDR-HC1 Mini DV Digital Camcorder
No picture sometimes
If the screen is still lit up then it's your lcd controller which will cause the screen to just be lit up but blank. If the screen does not stay lit up then it's your backlight inverter(s) in this case you should be able to hold a flashlight up and still see the picture on the screen just very dark.
Aug 22, 2009 | Sharp AQUOS LC-32D43U 32 in. LCD...
Display screen is black
I've been told it's the LCD Screen. I have a new LCD screen but now can not find any instructions to change it out. It is not in the manual. I wish I could help. And this sight appears to be complete useless.
Jun 24, 2009 | Nikon Coolpix S550 Digital Camera
Cleaning a touch screen
use micro fibre cloth make it damp not wet and just clean the screen , u can try it dry but cloth needs to be special type micro fibre used to clean LCD 's
pls rate me FIxya for help
Apr 22, 2009 | Nikon COOLPIX S60 Digital Camera
Sony Cyber-shot  DSC-N2 Digital Camera Logo
176 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
