Question about Maytag Neptune MAH5500B Front Load Washer
Front loader maytag neptune wont start
When i try to start the washer somtimes it will start and run for about a miniute or two but will shut off or it won't start at all. I checked the voltage and it is O.K.. Want to know if you might have a solution. thank you for your time. you can call me at 1-916-803-3739.
    Scholar:
  • 196 Answers
Check the door switch. Sounds like the wax motor is not fully engaged.
Posted on Jan 15, 2008
MY MAYTAG NEPTUNE FRONT LOADER WASHER KEEPS SHUTTING OFF AND THE E3 ERROR MESSAGE IS ON THERE
Transmission or clutch assembly not engaging due to going out or slipping. even bad door switch
Sep 20, 2014 | Maytag Washing Machines
Our maytag neptune frontloader won't start
CHECK PLUG FUSE IF OK CHECK WIRE FOR ANY BREAKS IF NONE THEN IT MAY BE THE ON /OF SWITCH IS FAULTY.
Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Won't spin or drain, have tried to rerun cycle and checked drain hose
Check pump / outlet filter , refer to instruction book , clean and replace then re- try
My maytag neptune washer smells musty. what is
I owned a maytag neptune washer and had to run dishwashing liquid thru it occasionally to get the smell to go away. Finally we learned about a new gasket retrofit that they were doing which was covered by the maytag company we called and they installed it for free and the smell stopped. I had that washer for about 10 years and probably spent as much fixing it over the years as it cost. I now have a whirlpool duet front loader and love it. no smell and not problems. Try the electric dish washer soap.
Aug 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
I have the neptune front loader. The lock light wont come on and the door wont lock. During a wash cycle the water just started comming out of the door. If I hold the stop/start button manually the light...
hi there,
you have a door latch problem. the reason you can still push on the button is because this particular washer has a time delay function. i would recommend taking a look at the latch itself and possibly the wax motor that runs the latch.
Dec 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
SUDS error on Neptune washer
It means that there is too much soap in the machine most of the time. Give it time for the suds to go down then try to run it through again. Try using a little less soap later on. Front loaders need less soap than top loaders.
Nov 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
MAYTAG Mah4000 front loader washer
HAVE YOU CHECKED THE MOTOR CONTROL BOARD?IT IS LOCATED INSIDE THE FRONT RIGHT BOTTOM OF WASHER BEHIND FRONT PANEL,LET ME KNOW IF YOU FIND ANYTHING-MIKE
Nov 01, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Depenable care-Top Loader
Hi dannybridges
With the 5500 series it is usaly the motor comtrol board. i would get a tech just to be sure casue it chould be the main board at the top but i doubt it.
brent
Sep 08, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune front loader won't start
Three items can cause this type of failure
1. Door switch
2. Main control board.
3. Keypad console.
Jan 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
144 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
