It sounds like you have it in RESET mode or it was udating the firmware from Itunes......1. plug it back in the computer that it was last used on when this happend or 2. Try manualy reset it yourself by holding the CENTER and MENU button at the same time for at least 10 seconds.
PLEASE make sure you have it charged up before you do this...(if it will) if it does not charge from your computer with the usb cable then try a external power supply or use a Firewire connection to the computer. Note that the Firewire will only charge the unit it will not be able to transfer music with it.........Good luck! :)
Was this helpful?
Yes
No
Popular Solutions for Apple iPod Video 30 GB Black
screen is frozen,on the top of the screen it says SDRAM full test,tells me to please wait...........
(More)
screen is frozen,on the top of the screen it says SDRAM full test,tells me to please wait........ RUN: bl on PASS:bl blink FAIL: bl off Reset to continue. but the screen is frozen so can't reset etc,help.-
apple ipod classic 30gb says to restore and after its done restoring it says failed. and then says...
(More)
apple ipod classic 30gb says to restore and after its done restoring it says failed. and then says to format disk but fails that also
