Question about Sapphire ATI RADEON X1600Pro 512MB DVI/VGA/TV-Out Graphic Card
Sapphire X1550 512m DDR2 AGP graphics card and NEC MultiSync LCD 175VXM+
Hi I've just upgraded my graphics card to the above from a Cirrus Logic Laguna 5464 all seemed to go ok untill it asked me to restart my computer on reopening all my Icons were huge and if I went on line I couldnt see google or whatever as it was off the screen! If I plugged my monitor into the other socket all I got was the screen saver in the middle of a blue screen and no icons at all. I tried to change the display in the display settings but it didnt make any differance. Please help as I've now disabled the new card and I wanted to view video but my old card wont!! I'm running Windows XP home edition and my mother board is ASRock K7VT4A+ I have Hauppauge WinTV, Creative SB Audigy sound card, I hope this is enough info to enable you to help me!
Thank you
  • 1 more comment
  • Thanks I'll get the updated drivers and thanks for explaining the two screens, I'll give it a try. This is my first graphics card installation so sorry if I sound thick!!!
  • Yes both card are still in my computer I didnt take the old one out because I thought I wouldnt have any screen if the new one didnt work! Sorry if that sounds thick but I've never done this before!
  • Hi I've finally got some of it running but had to remove the old card for my computer ( not just disable it) BUT I cant see video! When I play a video via widows media player 11 I get a black screen and I dont know what to do now!!!
    President:
  • 2,351 Answers
For now keep your old video card in the PC. Please upgrade Windows Home Edition through Windows Update. Your system needs to have .Netframwork 2.0 installed for your new video card to work as intended. Do not skip lower versions of .Net framwork as you update. Do not install more than 1 .Net framework at a time & do not skip any. Once windows is updated, download ATI's Catalyst Software Suite at this link.
Save the updated X1600 drivers in a folder on your drive.
http://game.amd.com/us-en/drivers_catalyst.aspx?p=xp/radeonx-xp File size 45.0Mb. Date Dec. 20, 2007.
Now open windows control panel & open Add or Remove programs. Uninstall your current video software for the Cirrus Logic Laguna 5464. Also uninstall the ATI Radeon software.
If while uninstalling the ATI Radeon software you get a error message & the uninstall fails. Download & run this ATI uninstall utility. http://searchna.ati.com/promosearch/?site=us-en&la=en&qt=cat-uninstaller&selectsite=ATI&sp_a=sp10039240&sp_p=all&sp-x-1=col&sp_f=ISO-8859-1&sp_q=cat-uninstaller&Search.x=9&Search.y=8
Shut down the PC. Install the Radeon X1600Pro video card.
Make sure the card is seated evenly in the AGP slot.
Start up the PC. Install the downloaded X1600 software. Restart the PC after install is complete. Even though you are using a single display you must enter the Catalyst Control Center to setup your display. You will find that you can not just switch between the DVI & VGA without using the Catalyst Control Center software.
Posted on Jan 06, 2008
    Sergeant:
    Champion:
  • 243 Answers
Have you got both card installed in the pc just now? Was just wondering as you said you "disabled" it rather than removed it?
If the old pci card is in there and the new agp one is too then that could certainly cause a problem.
Also before installing the new card did you properly uninstall the old cad in device manager?
After uninstalling the old card you need to run a free progam called driver cleaner pro from here
http://downloads.guru3d.com/download.php?det=745
It removes traces of any old drivers that may cause problems with new ones.
  • Graeme Fallows Jan 07, 2008
    Do you get sound playing?
    You will need to install a codec pack to get some dvds to play. This is the one i use and never had any problems :)
    http://www.free-codecs.com/download/K_Li...
    Do all your games run ok now?
    Old card being left in was causing the problem then :)
    Hope that sorts it for you?
    Scholar:
  • 135 Answers
Did you install the latest drivers from the AMD (they bought ATI) website?
You can find the latest drivers for Windows XP Home here. After you install the drivers there should be no problem changing your resolution. Regarding the other socket, you must've made it so you extend your desktop onto your "second screen" (ie. the one that connects to the second socket) so you don't see your desktop on that screen but just the extension of your desktop. If you move your mouse all the way to the right you should see it pop up there. You can change it in Display Properties -> Settings -> select screen #2 and deselect the extend desktop onto monitor option.
  • Yonatan Horan Jan 07, 2008
    This could be one of two issues:
    1. The drivers still aren't installed properly, or your previous drivers are interfering. You should right click My Computer, go to Properties, then click on the Hardware tab and click on Device Manager, under Display Adapters you should have your new ATI card. If you have the old card showing up there, right click it and uninstall. If you have any device other than the ATI card showing up there, please post what it is here so I can further assist you. If you didn't already install the drivers (the ATI Catalyst software), you should install it now. You can download it here.
    2. You might be playing a DivX file without having the proper codecs. Are you playing a .avi file? If you are and didn't install the codecs, download this codec pack. Then, try playing again and see if it shows up. If not, what is the extension of the video file you are playing?
Packard bell imedia 5064 specs
I currently have installed is Ati Radeon HD2400 AGP 256MB graphics card and im looking to upgrade it to this Sapphire Radeon HD3650 512MB AGP Graphics Card will it risk my computer to overheat, or is my computer not good enough to run such graphics card
May 21, 2014 | Packard Bell iMedia Computers & Internet
Windows 7 do not accept (my Sapphire 4650 Hd Agp ddr 2 1gb graphic card) drivers when I upload drivers .how I will make upload for my computure?
This is Sapphire's link for downloads:
http://www.sapphiretech.com/presentation/downloads/download_index_01.aspx?psn=0006
I entered your info and it appears the card #100288L Radeon HD 4650 1GB DDR2 has Windows 7 support. This card requires a 400w or greater power supply and, a 6 pin power hook up. You have to un-install the VGA driver and Catalyst control center before downloading new. You can do so in a "custom" uninstall then, a "custom" install.
http://support.amd.com/us/Pages/AMDSupportHub.aspx
You can also try to update your drivers here.
Jun 07, 2011 | Sapphire RADEON HD 4650, (1 GB) AGP Video...
I want to download cirrus logic cl - gd 5440 vga card driver please help me with it i cant find it even on cirrus logic website
http://www.driverfiles.net/Video-Adapters/Cirrus-Logic/page%2Clevel2%2C51%2C5%2Cresultpage1.html
Copy and paste the link above to your browser. Good luck
Jan 28, 2010 | Jaton Cirrus Logic 5440 (1 MB) Graphic...
Want to upgrade graphics card. Which is the best to go for?
http://www.pcw.co.uk/personal-computer-world/hardware/2217776/review-sapphire-hd3850-agp
which is the ATI 3850 or the Nvidia 6200
Apr 17, 2009 | Computers & Internet
I need just an advice
Dear am_shaegar.
You have provided a list to chhose from.
I bet , hd2400 is the est solution for you couse all the others have the geforce 6200 chip wich is old and slow.
So a HD2400 is best for you.
Good luck, borney from Hungary.
Mar 22, 2009 | Abit KV-85 V2.0 (KV85VERSION20)...
Can i upgrade the graphic card i have - Radeon 9600 256 MB version 8.33?
sure, that card should be an AGP card and they make many faster cards that are AGP slot.
Mar 16, 2009 | Sapphire Technology ATLANTIS RADEON 9600...
Download vga drivers
http://www.driverfiles.net/Video-Adapters/Cirrus-Logic/page,level2,51,5,resultpage1.html
copy paste the above 2 lines into address bar
go to the above web site your drivers listed for download
Aug 02, 2008 | Jaton Cirrus Logic 5440 (1 MB) Graphic...
Graphics Card
see if you have an AGP, OCI, PCI_E slot available first.
most G-Force and Nividia cards will have the connections needed. Monitors will run basically on any card.
Jun 22, 2008 | Computers & Internet
Sapphire ATI RADEON X1600Pro 512MB DVI/VGA/TV-Out Graphic Card Logo
1,554 people viewed this question
Top Sapphire Computers & Internet Experts
Rajendra Singh
Rajendra Singh
Brett Duxbury
Brett Duxbury
Bill Boyd
Are you a Sapphire Computer and Internet Expert? Answer questions, earn points and help others
