Hello All, I think I saw a partial solution to my problem with the Cannon BJC 85 scanner feature on...
(More)
Hello All, I think I saw a partial solution to my problem with the Cannon BJC 85 scanner feature on the Vista forums. For some reason the scanner cartridge is not compatible with Vista o/s. I was able to download the IS 12 scanner program partially onto my computer using the Windows 98 mode as mentioned by the guest hgdffkhdf . I also saw a posting by benguile3@gmail.com about ISScan_v350.exe as being a solution. Could anyone give me more detailed instructions on how to make the scanner work on Vista o/s?
this model does work still, but printing out faded ink labels. I need a ink roller replacement for...
(More)
this model does work still, but printing out faded ink labels. I need a ink roller replacement for it. No where to be found on the internet...so does that mean there is no such ink replacement exists.? HELP!!!! I have the same problem also. How do you replace the ink supply???
In caps all the vertical lines are not printed. For example: with the letter "L" only the...
(More)
In caps all the vertical lines are not printed. For example: with the letter "L" only the bottom line will print and not the rest so it looks like an underscore and not the letter L.
(More)
