Home | Maytag | PAV2300 Top Load Washer | Leak in the front of wah...
Maytag PAV2300 Top Load Washer
Problem for Maytag PAV2300 Top Load Washer
Leak in the front of wahing machine one of the
By nelsoni1 on Nov 09, 2009
leak in the front of wahing machine one of the hose how do we get to the hose
Solution #1
posted on Nov 09, 2009
Not Rated)
flatech
Rank: Guru
Rating: 97%, 15 votes
At the top of the machine where the controls are at look for 2 screws (Usually philips) either in the front of back of the top base.
Unscrew those and then the top piece can be removed easily.
Once removed pop the two metal brackets out with a flat screwdriver, and unplug the lid switch.
At this point you should be able to remove the entire top to have access to the inside.
Good Luck!
Was this helpful?
Yes
No
Popular Solutions for Maytag PAV2300 Top Load Washer
Questions and Unsolved Problems for Maytag PAV2300 Top Load Washer
Do you recommend Maytag PAV2300 Top Load Washer?
Answer
Answer
what causes a high pitched noise when it starts to drain the water before spinning
Answer
Here is the cycles: Fill machine for wash...OK Drains...OK Fills for rinse cycle.....OVER FLOWS Any... (More)
Answer
my Maytag top load brake sqeals when it stops in the spin cycle
Answer
I Have a Maytag performa Pav2300AWW Model that has quit. It made a squaeling noise like it was... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Maytag PAV2300 Top Load Washer:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14740
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
