Sound Cards
Problem for Sound Cards
Generic problem for all Sound Cards
I cannot remove the fan to replace the cpu...
By prickelypear on Nov 09, 2009
I cannot remove the fan to replace the cpu chip
Comments:
Nov 10, 2009
- Hi Ben, It is not a soundcard related problem. When I power up the PC it performs the POST ok but then a few miniuts later there are 2 beeps and the CPU fan shuts down and the PC turns off. It is an ASUS motherboard P55800VM
Nov 10, 2009
- Hi It is an ASUS P55800VM motherboard. I suspect it is the CPU chip itself. The PC performs the POST and then a few mimiutes later there is 2 beeps and the CPU fan shuts off and the PC turns off
Nov 10, 2009
Clarification Request
Posted by Techie_Ben on Nov 09, 2009
This sounds more like a mother board problem and not soundcard related. Please re-submit to appropriate area. Thanks
Posted by parrotheadpc on Nov 09, 2009
We need the make and model to be able to help you......
Posted by Big_Lebowski on Nov 09, 2009
Motherboard and system model numbers would be needed for accurate instructions.
Best Solution
posted on Nov 10, 2009
Very Helpful)
parrotheadpc
Rank: Guru
Rating: 89%, 543 votes
Sounds like the processor is getting an overheating code and shutting the system down or the processor is cooked and can no longer function. If you are trying to get an intel cooling fan off an intel chip, there should be four posts holding the fan in place, these posts turn 90 degrees and then when all four are turned , pull the fan off the mount. If yours does not have the four post mount, then it may have clips on either side of the heatsink, these should just be pried away from the mount and the heatsink will be free. If the heatsink is stuck to the processor, you will need a flat plastic pry tool to wedge under the lip of the proc and heatsink to separate them.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Sound Cards
Questions and Unsolved Problems for Sound Cards
Answer
Changed my acer PC Veritron 6800 from Spanish to english and lost the sound. Downladed the driver... (More)
Answer
i need to download the software for my cavit u50 i lost my disc
Answer
Focusrite saffire with hissing/buzzing/distortion on the line in 1 and 2 I've been having this... (More)
Answer
Hi Guys, I have a Hercules 16/12FW ext sound card. I'm unable to get the installation program to see... (More)
Answer
i get this messeg when i try to play muice or vids how can i fix this.(Windows Media Player cannot... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sound Cards:
Top Sound Card Experts
Rank: Guru Guru
Solutions: 14807
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Sound Card Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
