Question about Philips 51PW9363 51" Rear Projection HDTV-Ready Television
Problem with the color on my TV
We have had this model TV for 5yrs now. Recently, we noticed that the color on the set is not right. The whole picture is very dark, and things that are supposed to be red show up black, just as an example. We have tried to adjust the brightness, and the picture, just as it tells you to in the owner's manual but nothing has worked. We are convinced that something is wrong in the back of the TV, but we dont know what it could be. Any advice that you could give would be greatly appreciated! Thanks!
Convergence problem cost about 2 hundred to fix
Posted on Jan 18, 2008
6ya staff
SOURCE:
What would effect the picture quality the color wheel or lamp?
The color wheel is your suspect.......usually whines a bit
when bad. In a quiet room, you can hear it when the TV is powered on or off. It spins at 9,000 rpm ( wears out the bearing).
The lamp will not exhibit those symptoms....
Apr 26, 2014 | Televison & Video
I can't get the color right. What are the perfect setting?
Hello!
Have you tried preset picture modes off TV's "picture" menu or "picture" on remote control unit. Most modern sets have "preset" modes: normal, vivid, natural, movie, sports, user, etc. Try to toggle between those modes. may be the one of those will look right for you. Make sure: "user" mode is for custo adjustments. You must choose desired settings: "picture(contrast)", "brightness", "color", "tint", "sharpness", "color temperature". May also have: DNR(dynamic noise reduction", "black level expansion", etc. I'd try presets, first and make notice of those settings. If that is, still not right to you, you may be able to tweak "user" mode the way you like it, based on info from other modes. If that won't help, you may have an issue with your TV.
good luck,
thanks,
Alex.
Sep 13, 2011 | Toshiba 19SLV411U 19 in. LCD TV/DVD Combo
Picture has lots of green
i think that your TV picture tube has a problem..tnx
Sep 09, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Color adjustment on Sony 36" Trinitron
Unfortunately, the CRT (Picture Tube) is reaching its very end. Your set is not feasible to service even if the CRT would still be available from Sony or any jobbers.
I would be seriously shopping for a new TV set!
Jerry G.
Oct 27, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Phillips Magnavox 60 inch Projection Tv
That model is famous for having bacterial contamination in the CRT coolant causeing halos, and dim pictures with bad overall color issues. You can look into the lens of the CRTs when the set is laying and if the coolant looks cloudy or has any growth there you will notice it right away, and changing the coolant will restore color, clarity and brightness.
Jun 15, 2008 | Philips Magnavox 9P6034C 60" Rear...
I will need to know what make and model your tv is.
Feb 16, 2008 | Televison & Video
Mitsubishi 60 in vs-60707
. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Aug 10, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Sony wega 36" blinking problem
Yes this sounds about right for a set this age.
May 02, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Right 2 inches on edge of screen are darker than the rest of the screen
What is the model of the TV? Samsung DLP TV's start with HLS,HLP,HLW.....
Feb 06, 2007 | Samsung TX-R3080WH 30" TV
Slanted picture
Your deflection yoke (a coil around the neck of the picture tube) must have gotten turned. Your can turn the picture upside down by rotating this coil. If your set is in warranty, you should return it. When this "yoke" is adjusted the color is affected too. If you try this yourself you'd void the warranty and mess up your color. Stargazer
Nov 05, 2006 | Philips Magnavox 20MT133S 20" TV
Philips 51PW9363 51" Rear Projection HDTV-Ready Television Logo
50 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
