Question about Brother MFC-8860DN Printer
Reset drum - brother mfc-8860dn
How can I reset a drum of printer brother model mfc-8860dn
  • 4 more comments
  • xterso Feb 07, 2008
    I think I have the same problem. I was getting "Drum near end" error so I have replaced the drum. But still I get the same warning and I see "0%" when I look at the parts life in the device menu. I have called the service but they refused to tell how to correct this problem. I guess they want to get money out of it for such a small issue but I won't definitely pay anything. Either I will find the solution or I will keep printing like this. Anyway, I can print well without any problem right now. Just the message is quite annoying.
    Any idea? How can I tell the printer that I have replaced the drum and everything is good and fine?
    Regards,
    Erol
  • Anonymous Mar 13, 2014
    toner won't reset
  • Anonymous Mar 14, 2014
    brother mfc 85100N printer
    reset the belt counter on MFC-9450 brother
  • Anonymous Mar 15, 2014
    drum end soon Brother MFC9320CW All-In-One Printer
  • Anonymous Mar 18, 2014
    How do I reset the replace toner on a brother printer MFC-8480
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Posted on Mar 16, 2008
  • 3 more comments
  • dayers52 Jan 21, 2011
    Thanks! This worked!!
  • jcjcj1
    jcjcj1 Mar 22, 2013
    Thank you soooooooooo much!
  • Dispatchgirl May 28, 2013
    My service manager was stuck, and this solution worked right away, thank you!!
  • Jesse Collard
    Jesse Collard Dec 19, 2013
    Thanks! Worked perfectly.
  • pittmand Jan 02, 2014
    Thank you, worked!!!
    Sniper:
  • 56 Answers
Drum error means dust on drum usually. Take out the drum/toner assy and there is a blue tab on top of the drum that slides back and forth. Slide it back and forth 10+ times and this should solve this issue. Make sure to put the tab back into the original position. Put the drum/toner back into the machine.
Posted on Jan 15, 2009
Not really. Already did this, drum life reports 96%. It just printed 1 page and then got the error again.
I've got this same thing happening on several MFC-8860DN units. We replaced drums, reset the drum counter by the procedure above, there's 96%+ life left on the drums, the Drum Error appears again. I reseated the drum assembly in the printer, checked the lever & spring contacts. Did the corona wire procedure so many times I feel like an idiot, power cycled the MFC -- left it off for hours, no change. After calling Brother to diagnose the problem we've replaced 2 of our 3 printers. I have other Brother MFC printers installed at other clients offices with no problems whatsoever. This promblem is chronic and intolerable.
Posted on Nov 14, 2008
  • Gabriel Castro
    Gabriel Castro Feb 04, 2015
    sorry ... check my comment at the bottom, ou may reuse your drum many times.... avoid wasting
    New Friend:
MFC BROTHER 8860 DRUM RESET
Put the drum unit and toner cartridge
assembly back in the machine.
Do not close the front cover.
Press Clear/Back.
Replace Drum?
a 1.Yes
b 2.No
Select ab & OK
To confirm you are installing a new
drum, press 1 .
When the LCD shows Accepted, close the front cover.
VERY SIMPLE, at this point you may check, press the menu scroll to machine info, select parts use, and select drum, it should say 100%
Gabriel..
Posted on Feb 04, 2015
Reset the page drum count
Posted on Feb 02, 2008
SOURCE:
REMOVE THE DRUM AND AND INSERT A NEW DRUM, THAT IS THE RESET
May 02, 2014 | Brother MFC-8860DN All-In-One Laser...
How to Reset the page drum count on Brother MFC-8860DN
Open door
remove drum and toner unit
remove toner from drum push on blue tab on side to release
reinsert new toner in drum
reinsert unit in machine
leave door open
hit clear/back on panel --- says new drum-- hit yes
says accepted
close door
Dec 11, 2012 | Brother MFC-8860DN Printer
MY BROTHER MFC-8860DN IS LEAVING "GLOBS" OF TONER ON THE SHEET WHEN IT PRINTS. CAN THAT BE FIXED?
Hello. this error is caused by the "drum". the drum can be replaced either through Brother or your local office supplies store.
There is no quick fix for this issue.
Regards GM
May 30, 2011 | Brother MFC-8860DN Printer
Brother MFC 8660DN "Toner Error Reinstall Drum I got a new drum, new toner and still printer isn't working and show the error reinstall drum unit please help
Pull the drum/toner out and look into the machine, at the wall on your left. There's a little plastic lever there that pivots to detect a new toner cartridge. Sometimes the lever gets sticky; wiggle it to free it up. If you feel brave enough to remove the outside cover of the machine on that side, you can put a dab of grease on the lever's pivot.
Apr 04, 2010 | Brother MFC-8860DN Printer
Looking for corona wife for brother 8860dn MFD.
Try to get some corona wire stock which was quite common back in the day and install it in your drum.
Aug 14, 2009 | Brother MFC-8860DN Printer
Poor print quality from Brother MFC-8860DN
Replace the drum. The drum is failing.
When you replace the drum open the front door of the machine where thr drum and toner is.
Hit the clear/back button. Press 1
That resets the drum count after you replaced the unit.
Nov 12, 2008 | Brother MFC-8860DN Printer
Print problems with brother MFC-8860DN
Brother mfc8860dn copier
Open front cover with power ON
press set
read display....
choose change drum and yes/ok
close cover
will reset bias voltage aka light copies, to suit new drum
Jan 11, 2008 | Brother MFC-8860DN All-In-One Laser...
Brother MFC-8860DN Printer Logo
29,383 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
