Just assuming you mean when the unit is running, If that is the case, it may be as simple as a small motor for the plate that spins.
Remove the plate and try the unit and see if that solves the problem, If it does the motors are fairly easy to replace.
Good Luck!
Was this helpful?
Yes
No
Popular Solutions for GE Spacemaker Microwave Oven
spacemaker LX1800 Light inside the microvan is not working. I think light bulb is off. how can i...
(More)
spacemaker LX1800 Light inside the microvan is not working. I think light bulb is off. how can i change light bulb. thanks
I realize the F3 error code indicates a shorted our key pad. I even saw the helpful fix-it...
(More)
I realize the F3 error code indicates a shorted our key pad. I even saw the helpful fix-it instruction sheet posted by a user. My question is can I buy just the membrane key pad with buying the entire GE assembly (item #134)? Despite being forced to list the product number above, my microwave model is JVM3660CF001
The microwave shuts down 4 seconds after pressing start and makes me reset dte/time and then does...
(More)
The microwave shuts down 4 seconds after pressing start and makes me reset dte/time and then does again
It makes a loud ,intermittent buzz-snapping sound when in use-like a short circuit-just started...
(More)
It makes a loud ,intermittent buzz-snapping sound when in use-like a short circuit-just started .Oven 6 or 7 years old.
