GE sidebyside, I have no water coming out of the dispenser. I did change the filter. I can hear the water sensor come on/orr when I push the handle (dispenser that engages the ice/water).
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
If determining the water line is frozen , there is a water dispensor heater kit , which comes with installation instructions , pt # WR49X10173 .
ge gss25jfph ww side by side. finally hooked up wtar line. water dispenses. no ice being made? looks...
(More)
GE GSS25JFPH WW SIDE BY SIDE. FINALLY HOOKED UP WTAR LINE. WATER DISPENSES. NO ICE BEING MADE? LOOKS LIKE WATER LINE TO ICE IS FROZEN EVEN IF THIS FIRST TIME HOOKING WATER TO SYSTEM? ALOHA,
