Question about Nextel i930/i920/i870 Stereo Headset [OEM] NNTN5774A Headset
Nextel 1930 i have a phone once the battery is put on a screnn pops up that is red green & blue n say insert usb cable ive insert the cable but nothing what can i do
  • moochie22 Mar 26, 2008
    the phone needs to be upgraded because the phone dosnt wanna come off the red green and blue
    Problem Solver:
  • 18 Answers
You may want to take your phone to a service center. If you are doing what it's asking of you and it's not solving the issue then a phone tech should take a look at your phone to make sure there is no damage causing this problem.
Posted on Jan 28, 2009
Charge light solid red
If you put a cool battery in a camera and the camera says it is too hot. you have a critical problem with either the battery or camera.
Sep 30, 2017 | Nikon Coolpix S6100 Digital Camera
T mobile touch pro 2 doesn't power on.
Take the battery completely out of it and let it sit for about 5 minutes. Then install the battery and see if it will turn on normally.
Apr 06, 2012 | HTC Touch Dual Slider Smartphone
The color seems messed up on its missing red or something..however if i turn the xbox on the colors are perfectly fine...whats going on? ive tried to adjust the colors but that does seem to...
If you are using component cables (red-green-blue) for your cable hook-up you may have problems with the red one. Check to make sure it is inserted properly at both ends. Note that there is also a red-white pair for sound. This is not the red one in question.
Sep 10, 2010 | Mitsubishi WD-73735 Television
It will not charge
I have the exact camera, when you plug it in does the USB cable show red? If so this means the cable and the battery are connected and the red is a charging status. If you can turn on the camera while it's plugged in then its not the cord or the camera but the battery. If it just fails to charge but does power up and connect via USB i would look into a new bettery. If the USB cable does NOT respond at all when plugged into the PC by itself then the cable is bad and you need a new one. It will flash red/green/yellow if it's 100% functional. If your cable does respond but does nothing when the camera is plugged in then it may also be the cable's connections or the camera's internal port has been damaged. If you want to make sure it is the battery then plug in your cable, wait for it to cycle through the colors and connect your camera WITHOUT the battery inserted. It should do nothing, then while its connected to the cable insert the battery, If the cable turns red but will not charge then it's 95% a battery issue.
Jun 28, 2010 | Samsung SL420 Digital Camera
Do you know the code to unlock a nextel ic502 it
Your phone is locked to a mobile phone provider. You need to contact this mobile provider to ask for the unlock code (security code) for your phone. You need to provide proof of ownership etc and the phone's unique IMEI number which is located inside the phone under the battery. They use this number to generate the unlock code for your phone.
They should provide you with instructions on how to enter this code into the phone.
Once you unlock the phone, then you can insert a new SIM card in the phone.
Nov 20, 2009 | Nextel Cell Phones
Blackberry curve 8900, red light will come on for eight seconds when connected to AC power then a battery with a blue lightning bolt will show up on screen. Once AC is removed device goes blank. I've put...
The battery is drain.
DO NOT use the USB cable to charge your Blackberry.
When the PC/Laptop/Mac go to power saving/SLEEP mode it will cut off the charge to the Blackberry.
Use the official AC charger to charge the Blackberry.
Make sure the AC power is not switch off to the power pack at night.
The mini USB connector can be loosen over time.
Plug in the cable and check for connectivity.
Oct 19, 2009 | Cell Phones
Treo 700 P red, white, blue, green checkered screen
Finally found this solution! It is a connection issue at the bottom of the phone where you would plug in the cable to hotsync your phone.
Put in your hotsync cable and wiggle it around really good and it will fix the issue. Do this with the battery out and then pop it in until you have fixed the issue. Took me a few tries as I was worried about how hard to do it, but no problem!
Jul 28, 2009 | Palm Treo 700p Smartphone
Replace flip on my nextel i850 phone.
1. Remove battery cover and battery
2. Remove the four T-6 screws from back of the phone (you will have to raise the antenna to access one of them)
3. Seperate the housings.
4. Disconnect the flex connector/data cable that connects the back housing to the motherboard.
5. Disconnect the cable attaching the flip to the motherboard (at top of board)
6. Remove keypad from old part and put it in the new part.
7. Insert motherboard into new flip/front housing and connect cable to board.
8. Reconnect cable from back housing to motherboard
9. Replace and tighten 4 screws and you are good to go.. very easy repair.
Mar 24, 2009 | Nextel i850
How to change the sims card on the i730 nextel.
The SIM card in a i730 slides out of the side of the phone. Remove the battery and simply slide the card to the right toward the push to talk button.
Once removed you will see a diagram that shows how to insert the new one. You need to insert it with the angled edge down to the left.
If it is a new SIM card you will need a SIM copier to copy the contacts from one card to another (if you want to)
You will also need to activate the new card before using it. Go to a Nextel store for this or try customer service.
Jan 16, 2009 | Nextel i730
Error 0.14
Nov 18, 2008 | Palm Treo 700p Smartphone
Radio Communications Logo
69 people viewed this question
Top Nextel Radio Communications Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Nextel Radio Communication Expert? Answer questions, earn points and help others
