Lynda,
Many times the return hose is routed thru the hole you described with no extra fittings or grommets. I suspect the hose cracked at that point, some of it fell inside the tank, and the rest is what you can see on the outside, so you may need to replace the hose with a longer one. The diameter needs to be larger than the hole as the 'press-in' fit seals the tank from leaking.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Fig.: 5.0L and 5.8L engine oil pan gaskets and seals
1987 5.8L Engine With 4-Bbl. Carburetor
