Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Will not drain
The water will not drian
  • 1 more comment
  • Anonymous Feb 07, 2008
    My washer is not draining the water at all. I noticed a buzzing sound, like the motor was jammed or something but it does everything else. What could be the problem?
  • GJolyn Oct 13, 2008
    Water will not drain after wash. If it is timer problem, how do I fix it? Thx
  • ranjmiller Dec 09, 2008
    My washer won't drain out the water. It will spin but no water comes out. Help.
The switch on the washer lid was bad, you can either short it by tying the 2 gray leads together, then the washer will spin and drain weather the lid is up or down ( not the best solution) or replace the switch, 25.00 to 45.00 depending where you purchase.
Posted on Oct 13, 2008
  • 589 Answers
If you were to open the lid, and close it right after the wash cycle (when it would normally start to drain), does it drain? Is the motor running at all, or does it immediately try to spin with the water in it? (as though it's missing the drain step) If so, the timer is partially shorted, and its not allowing it to go into the drain cycle.
Posted on Jan 08, 2008
    Sergeant:
    Champion:
  • 310 Answers
The timer wheel might be loose. you need to get it to turn 1 or 2 clicks more clockwise
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Posted on Jan 07, 2008
Water wont stop draining when in wash cycle
In the front load washer is use the drain pump to drian out the water. so the water out tube (pipe) was hang up hihtger them to washer tube. your machines problem I thinh it is the drain out tube (pipe) was fall down lower them the washer tube.please correct it.
Jul 11, 2011 | Washing Machines
My washing machine has two flashing lights and it want drain the water it just stops half way through i think my water pump is broken
machine wont spin while it has water in my advice is to lay the drain pipe level with the floor (outside of your house) so it can drain if it doesn't drain then you have a blockage anywhere from the drum outlet into the pump to the water pipe if it does drian then take the pump apart and check it turns freely
Jun 04, 2011 | Washing Machines
My samsung DB.710DB dishwash has standing water after a complete cycle, I've removed the baskets and arm to try to get to the drian screen what next
Check your drain hose and the house plumbing the drain hose enters for blockage. make sure your drain hose isn't severely kinked.
Feb 06, 2011 | Samsung Dishwashers
Water builds up at bottom of unit and begins to drain out of the bottom left corner.
is it level water will go to lowest point is the outlet of drian clogged level and pour water in it to see if it will drain properly
Sep 11, 2010 | Heating & Cooling
Washing will not hold water. it fills and agitates while it slowly drains
check the drian hose to see if it is to fare down the drian often it only needs to be six inches if any more it will sifion its self out
Jan 23, 2010 | GE 3.2 cu. ft. Washer
Pegasus Push Button Drain leaks when you push the button
REMOVE THE LOCKNUT AND CHECK FOR A CRACK OR PIN HOLE IN DOWN DRIAN USE A FLASH LITE IN DRIAN TURN OFF ALL LITES TO CHECK PUT LITE IN DRAIN AND CK FOR LITE IN THE DRIAN PIPE
Mar 09, 2009 | Plumbing
Water in rear quarter panel
This is a known issue whne the car is running down the road a vent flap will open up and road spray will get into the trunk. There is also issues with the convertable model. that isknown by ford.
Dec 13, 2008 | 2006 Ford Mustang
Halp
Hello it could be your lint filter or a hose is blocked by an object. May be even in the pump. Had a similar problem with our Maytag. Cheers.
Mar 08, 2008 | Washing Machines
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
50 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
