Question about Nintendo DS Console
How to change a ds case
My daughter has a nintendo ds and a friend knocked it out of her hand,the plastic round the hinge has broken and we have ordered another case, everything still works on it but we are unsure how to change the case,is it simplewe have sent for a tri star screwdriver can someone please help
  • snook8 Jan 16, 2008
    I have the same problem with one of my DS Lites. I read the instructions from the link and am ordering a full shock case to see if this will take care of my problem. I'll let you know if I have a problem.
    I also have one that when you turn it on it flashes briefly then shuts down. I'll research to see if someone knows what to do for that too.
    Thanks for the info! I Luv this site!
    Donna
I swapped one of these into a new case recently for someone following this guide:-
http://site.powergamingparts.com/RepairNDS.html
I'm no expert at fixing things and it was fiddly in places but DS works fine now and looks smart too!
Posted on Jan 11, 2008
Ds lite top screen
Yes its fixable but it depends on what has broken.
There are two possibilities the small barrel hinge has broken, this is just a case of fitting a new one by opening the case, unscrew the light and gently pulling the top of the case away till you can change the barrel hinge.
The other one is the case has broken and is not holding the barrel hinge, can bodge it with some glue sometimes but most often you need a new case.
Jul 09, 2009 | Nintendo DS Lite Console
NINTENDO DS BROKEN "PLASTIC RING HINGE"
nono no dont my ds had the same problem it will work as long your extemely careful but if you drop and a hinge missing the top screen will break and it is unfixable i have tried
Mar 24, 2009 | Nintendo DS Lite Console
Ds lite hinge is broken is there an easy fix
There web sites where you can get a new case for your DS. When searching try using : nintendo ds lite replacement shell or nintendo ds light case modding
Feb 25, 2009 | Nintendo DS Console
Nintendo ds lite has a broken hinge
You can buy a new plastic housing for your DS lite on many different sites. Some are great quality. If the DS still works (despite the broken hinge) it makes sense to replace the housing.
You should be able to find enough videos on youtube to learn how to disassembe the DS and not do any harm. Make sure that you buy a tri-wing screwdriver (also called a nintendo screwdriver).
Hope this helps
Dec 23, 2008 | Nintendo DS Lite Console
Hinge problem
There out it is nothing like a broken hinge only repair solution, the only way to get it repaired is to buy a new replacement shell and replace the broken parts or the whole shell, but some cheap shells wont last and will broke again so read reviews. And if you are not too skilled be careful when replacing or you can get your DS more damaged.
The best is to find a good case broken DS, like water damage etc. to get only the original plastic parts. I should love to have to buy only the broken parts needed but you have to buy the whole thing.
Nov 14, 2008 | Nintendo DS Lite Console
Cracked hinge and chipped corner on DS LITE
yes the shell can be replaced, you can either check ebay or google nintendo ds lite shell housing, i have seen them, doing this yourself is no easy task, there is a repair service on ebay under repair service fix nintendo ds lite
Aug 05, 2008 | Nintendo DS Lite Console
How difficult is it to replace the casing for a nintendo ds?
U need to find someone that can repair it in your area. Email me at whiteyboyz@gmail.com if u live in australia and i can give u a link to someone who can fix it.
Dec 14, 2007 | Nintendo DS Console
Nintendo ds - broken hinges
Try gripping them with a pair of long nose pliers and pulling them out. I'd advise a layer of cloth between plier teeth and rods, to stop them being gouged.
Nov 16, 2007 | Nintendo DS Lite Console
Nintendo ds to screen broken
Hi, replacing the original nds upper screen is a fairly straight forward procedure, you need to remove the 4 x small plastic plugs located in the corners of upper screen, then remove the 4 x phillips screws, the top outer back part of the case will seperate and you can gain access to the screen. Firstly remove the small screw holding down the right hand pcboard to gain access to the ribbon connectors, release the larger flat connector by hinging the clip up, slide the ribbon out, underneath you will see a tiny connector, gently ease the small clip back towards the ribbon, prising a little each side at a time, remove the ribbon and then you can prise the screen from the case.
These guys sell the replacement screens www.ps2laser.co.uk prices are very competitive and offer next day delivery!
Nov 08, 2007 | Nintendo DS Console
Nintendo DS Lite top screen broke on one side
The only way you can repair this properly is to replace the casing with a new one... the hinge is a common problem and over 90% of my customers on the DS and DS Lite need a new case due to broken hinges. Once the plastic bit has broken then it will only get worse. The small bit that you say fell out was the actual hinge itself (a small black part with a silver end that twists and locks your console into place when open). Hope that helps!
Aug 21, 2007 | Nintendo DS Console
Nintendo DS Console Logo
2,919 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
