I had been unable to print as The magenta toner said low in on display. I changed toner and now it says c toner low. It will print though. Is ther some way to check toner cartridge levels to see if they are empty or not?
pages get stuck, won't feed thru the machine...getting error message: service call 15 H...any...
(More)
pages get stuck, won't feed thru the machine...getting error message: service call 15 H...any suggestions?
Just replaced the drum because I was getting vertical striping on the left side and I'm still...
(More)
Just replaced the drum because I was getting vertical striping on the left side and I'm still getting multicolor vertical striping with no error messages. HELP!! mike w
What appears bright blue on the screen is coming out a purple sort of colour on the paper. Any...
(More)
What appears bright blue on the screen is coming out a purple sort of colour on the paper. Any ideas?
Setup completed but which port should be used? Using windows XP Original user was directly connected...
(More)
Setup completed but which port should be used? Using windows XP Original user was directly connected from computer to printer using a network cable.
