-   I have a 5 year old Hitachi 50V500 UltraVision projection TV and the picture color is too red.
I had a repair man out and he said a refurbished part would cost ~$700 and a new part would cost ~$1,200.
What is the part I am looking for and can we get it for less and install ourselves? -   Caryn Beeson
Jan 26, 2009
-   My Hitachi 50UX58X screen turns green. I tap the side of the TV and it goes back to normal. It is only happening a couple of times a night but it is getting anoying. Any Ideas? -   RwhitmanF16
Jan 05, 2009
-   About three years ago my hitachi 50v500's picture turned red.
The repair shop wanted about $1200 to fix the set. Itwas out of warranty by 2 weeks. After reading all the complaints from 50v500 owners and trying to get Hitachi to fix it, I decided to purchase a new TV.
It was a good set while it worked.
-John Crane-   Guest
Nov 16, 2008
-   MY TV
HAS A RED PICTURE AND IT WAS REPAIRED ONCE. THE PICTURE IS RED AGAIN.
WHAT CAN I DO. WHERE IS THAT BULB LOCATED SO I CAN REPLACE IT MYSELF.
-   Guest
Nov 11, 2008
-   Mine started as a red cloud and has grown to cover the whole screen. You can still see picture but the integrity of the colors on the screen is gone.-   Guest
Hello
This is usually not a repair a layman is able to do
as the ammount of plugs and wiring that go with it.
also the tubes have to be set up after installation .
The actual problem may be the red driver transistor or a cold solder joint.
I recommend a tec. to repair it.
Thanks Guy9
the problem is most likely a defective light engine, it is a very commen problem with these tvs. hitachi is not very forthcoming with information or help unless your still under warrenty, i have talked with a few people about this and have found a lawyer starting a class action suit, if interested here is a segment of another conversation with all the info to get you started. " let other HitachiTV owners know about the Class Action Lawsuit against Hitachi regarding the defective optical light engine. They need to call the Law Firm in Dallas Texas, HORP & B, that you mentioned is handling the case and talk to Victor @ 1-877-308-7900. They are taking documentation and cases regarding this suit and people that feel like they have been treated unfairly wherein Hitachi denied sending them a new optical light engine @ n/c need to call and state their case. " good luck with your problems
Comments:
Aug 14, 2008
- the bulb is accessed in the front just under the screen on the left side. it comes in a black box and is not removable from the box. you have to replace the whole assembly the bulb is in. it costs about 250 dollars depending on where you buy it, i recomend ebay, there is a very respectable seller there and it should be cheaper than a distributor
the tv picture began to get wavey lines at the top of the screen for a short time then the tv screen...
(More)
the tv picture began to get wavey lines at the top of the screen for a short time then the tv screen went black.
