Question about Cameras
Vivitar Electronic Flash 2000
Hello
is the Vivitar Electronic Flash 2000 compatible with a digital canon rebel Xt
Thanks a lot
  • 4 Answers
SOURCE: Canon Digital rebel Wont turn ON
This happened to me today. The lens drive sounded weird - like off gear. Then it froze and wouldn't turn off without taking out the batteries. Then, it would turn on. Now it's ok. What I did was remove the cf card, lens, regular battery, and the little battery that is also in the battery compartment. I let it all sit while I did other things. When I put it all back together it turned on and I had to set the date but everything worked fine.
Posted on Oct 22, 2007
SOURCE: Error 99 only when flash pops up
We ended up sending the camera in to Canon. $200 unless they find something more wrong. Luckily we have my Nikon D80 still. I will say that Canon replied via e-mail fairly quickly and one paid, said 7-10 business days for the repair.
Posted on Dec 09, 2007
Gryfox
  • 216 Answers
SOURCE: canon digital rebel 350D
The first thing to check is that the card door and battery door are firmly closed - press on them while the camera is on to see if it powers up. If not, there's probably a blown fuse - it will have to go to the shop.
Posted on Nov 27, 2008
  • 10 Answers
SOURCE: No Power To Canon Digital Rebel XT
Change out the CR2016 3V battery. You have to remove the rechargeable battery to get to the CR2016. Refer to the manual for proper instructions.
Had the same issue with a two year old camera. This solved my problem.
Posted on Jan 01, 2009
  • 15 Answers
SOURCE: Vivitar flash user manual
A new company has bought Vivitar from Synatx Brillion - Sakar is in the process of uploading the user manuals at this time. However they will not continue to validate any warentees that were before August 2008. Try looking here www.orphancamera.com
Posted on Feb 05, 2009
Canon eos digital rebel xt service manual zip
Hello friend, you can find the canon Rebel XT service manual in below link:
Canon Rebel XT / 350D / Kiss Digital N service manual:
http://goo.gl/gzAKSQ
Good luck on repairs.
Sep 22, 2013 | Cameras
Sounds like loose part in Canon 350D / Rebel XT
This is nothing to worry about. The sound is made by the metal linkage inside the flash housing. Pop up the flash and touch the linkage with your fingers. You will see there is a little movement. This movement is enough to make the sound you hear.
Jun 08, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Vivitar 2000 with canon xs
Trigger voltage doesn't have anything to do with the power source. Even though you're only giving it 6V (4 1.5V batteries), it ramps it up internally for the photo tube.
Old cameras used a mechanical switch to fire the flash, so the voltage didn't matter.
New cameras, like your XT, have an electronic switch and eventually will burn out, like Anonymous said. They want 6V at the hotshoe. You're giving it 56V... I know it works now, but it'll fry it eventually. You can get a hotshoe adapter that will isolate the voltage from the camera.
Dec 25, 2008 | Vivitar 2000 Flash
Built-in flash
do you get an error message? if yes the screws which are on the sides that hold the stainless steel slider bars could be missing the nylon spacer shims. a common fault
Jun 15, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Rebel Xt Sometimes when I try to take a pic it will not work!
one of my cameras does that. I shorted it out by using a non-compatible flash attachment. might need to take it in for repair. works fine without the flash though.
Jan 16, 2008 | Canon Rebel XT / EOS 350D Digital Camera
My new Canon Rebel EOS XT will not work with my external flash. WHY??
Hi , connection from camera to the quantary ps-1 dszflash are compatible the adopter it connect during flash signal.You may return and bring your camera and test what ever compatible.
Jan 05, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT
It is normal. Camera lightens surrounding to get focus point.
Oct 30, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Wont work
According to the Canon feature chart I have here; the 540EZ Speedlite flash is not compatible with the Digital Rebel XT in ETTL mode. The 480EG is also not compatible. The 550 or any of the others in that product line are would work. David Millier Advance Camera Repair
Feb 26, 2007 | Canon Speedlite 540EZ TTL Flash
Cameras Logo
523 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
