a friend installed vista. the computer had been broken for a while i am now trying to re connect to wireless. i have got so far but have now been presented with ' the network is a hidden netwok please make sure network settings match the wireless router settings' the problem is i have no idea what to do next. i can pick up an unsecured network nearby but that says local only. earlier today i managed to pick up my own network but mine too said local only. i now cannot even get back to my network. any help appreciated.
Comments:
Nov 10, 2009
- close and yet so far, computer now say's i have local and internet however when i try internet explorer it tries dial up and also says i am working offline i have unchecked this however when i try explorer again the same thing happens dial up and working off line. any ideas and thanks for help so far. cheers
1st connect with landline cable. Make sure all is working fine. Then enter a command prompt. (Start-Run->cmd {Enter}) Type "ipconfig". The gateway should be either 192.xx.xx.xx. or 10.xx.xx.xx. If you have a small network then your gateway is probably your wireless router. If your router is not your wireless device you will have to find it using ipscan.exe or scanner.
Let's say for arguments sake that your gateway is your wireless device. Open up a browser windows and input the gateway as "http:// gatewaynumbers ". At this point you need to check your wireless settings.
You need your SSID, Wireless Security (WEP, WPA, etc.) encryption, and passphrase" from your wireless router/access point.
(Note: unless you are the only one using the router try not to make any changes until you clear it with other users)
Check to see if your router has mac filtering on or off. Off is better while troubleshooting. Another term for MAC address filtering is Wireless Card list, there are others but it depends on the router you are using. If MAC or IP filtering is on then you will NOT be able to connect to the SSID unless you are on the list... hence disable for now is good idea.
Disconnect from wired landline (you should not have two connections wireless and wired at the same time). Assuming that your Wireless device driver is working properly (see Device Manager under network devices) you should be able to right-click your wireless device on the taskbar and select view available networks. You should see SSID here. Input your info and you should be good to go.
If not you will have to enter SSID manually in the Network Connections area. Right-click Wiress Connection from Network Connections and Select properties. 2nd tab should be wireless connections. Click the Add button and enter your information and click OK.
To test you should be able to go to a command prompt and type ipconfig and get numbers similar to when you had landline connected. To test your internet connnection type " Ping yahoo.com" and you should get 4 replys. Hope this help. Best Regards, -
Cameras Sharp sharp ar-5316-paint the No. 2 Li* + box I would like to send
Machinery until you...
(More)
Machinery until you return to Dsna coude reset sharp ar-5316
I reebot my computercause to much memory but now when I try open internet is a error no find...
(More)
I reebot my computercause to much memory but now when I try open internet is a error no find harddrive what is that mind , I have my originals CDS but i don't know if I can fixed maybe somebody there can help me thx.
case power for front of case to short for new ASUS M3N78-VM Motherboard, need a solution on how to...
(More)
case power for front of case to short for new ASUS M3N78-VM Motherboard, need a solution on how to cure
