Question about Malber TD700 Electric Dryer
Malber dryer 2 years old
The dryer does not start, it does nothing
  • 1 more comment
  • Anonymous Jul 31, 2008
    the light comes on and it makes noise that all it does it does not spin no more
    the light comes on and it makes noise thats all it does it does not spin no more do tou think its time for a new dryer we had it for 7 years
  • Anonymous Aug 15, 2008
    bought a new one, doesn't start
Move the dial to the "off" position first; wait for beep; then move to the drying setting you want, and wait for another beep.
Posted on Apr 06, 2009
  • 55 Answers
You need to press the "half load" button in to run the dryer. You may also need to press the "cold" water button in. If this doesn't solve, let me know.
Posted on Jan 25, 2008
6ya staff
SOURCE:
Water leakage at the faucet connection. is it a new D280 that i need? this one is only 2 years old but i can't think of any other reason. now that joel is gone, who do i call in nyc? thanks, j
These European machines have "English" (Whitworth) threads on the hose connectors. They look like American standard (NPT/NPS) threads used on everything here in the States, but are slightly different. Consequently, your hook-up hoses are special, having American NPS threads at the faucet end, and Whitworth threads at the Washer end.
Buy them from Malber. You can find Malber Distribution Corp online, or call them at 516-323-5299. Tell them Mike, in DC, says hi.
Oct 26, 2012 | Malber WD1000 Front Load Washer/Dryer
DRYER VERY NOISY AND VIBRATES
does it complete all cycles?
and how old is this unit?
Jul 25, 2008 | Malber TD700 Electric Dryer
I HAVE A MALBER TD700 AND IT WONT START.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 10, 2010 | Malber Dryers
8 year old Malber non-vented washer/dryer
It depends on the machine and if it's in good shape a new set is going to cost you $1200.00 a pump about $100.00 plus labor Its really up to you if you can afford a new unit or not. You may want to ask the repairman if he thinks the machine is good enough to keep, If there is any hoses or belts since he has it a part it will save some labor and would be some preventive maintenance may lube rollers or anything else he might see. But the guy working on it would be able to see if there s any metal wear or wear on rollers and could give you a better answer than we could.see may see something that may be make it not worth it. hope this helps and thanks for using fix-ya.
Mar 25, 2010 | Washing Machines
Dryer stopped working after working w/door open or closed
Sounds as if the door switch/latch had stuck.the smell was probably a small short. try unplugging unit. But I would imagine you need door latch/switch replaced
Feb 06, 2009 | Malber TD700 Electric Dryer
My 7 year old Malber WD 1000 won't dry - Where to order heating element?
pete5runner back again: The check you should make is to disconnect the two wires to the heating element carefully (with unit unplugged). Then connect a 110 voltmeter to the two wires. The plug in the machine and start a dry cycle. If you see 110 volts on the voltmeter, then you know that power is getting to the heating element, and you have isolated the heating element as defective. If you need a heating element, I got one in NY by calling 718-767-7396. New element was $29, shipping included. I don't know if he will ship to where you are located. Good luck, and let me know what happens.
Mar 10, 2008 | Malber WD1000 Front Load Washer/Dryer
Getting the dryer to start after turning it off.
Suggestion: Switch off wall plug and restart to dry.
Jun 26, 2007 | Malber WD1000 Front Load Washer/Dryer
Dryer has power but won't start
have you verified that power is actually getting to the unit? the symptoms to describe a "start capacitor issue" are excessive current draw and hum noise when starting. your dryer most likely uses a different starting method: motor has 2 coils, one for start, one for run.
Jun 04, 2007 | Malber TD700 Electric Dryer
Machine runs, but clothing won't dry
It sounds like your heating element is shot. The elements on this machine are very sensitive and if you use too much cleaning fluid the part will wear down after a while. You will need to get the part replaced (yuck) and start to use a little less washer fluid. Please let me know about your experience with the company ([email protected])
Sep 16, 2006 | Malber WD1000 Front Load Washer/Dryer
Malber TD700 Electric Dryer Logo
233 people viewed this question
Top Malber Dryers Experts
Marvin
Marvin
jimorris77
Are you a Malber Dryer Expert? Answer questions, earn points and help others
