Fahrenheat Built-In Baseboard Thermostat Heater
Problem for Fahrenheat Built-In Baseboard Thermostat Heater
I am trying to install a fahrenheat f2543 heater
By dumb_dog90 on Nov 09, 2009
i am trying to install a fahrenheat f2543 heater with a fta2a double pole thermostat. there is a 12/2 wire coming into where the heater is being installed. how do i connect the red and black to the white and black.
Solution #1
posted on Nov 22, 2009
Not Rated)
shastalaker7
Rank: Guru  Air Conditioners  Expert
Rating: 91%, 92 votes
Hi, this is very easy for you to do.The 12/2 Romex wire coming in is the power which you know. What you do need to know, is the voltage coming in? Sometimes they will use 12/2 Romex with ground for 220, 240, operation. You need to know if the T-stat is Line voltage 220, or 240 volt. You have to have the same voltage for both for it to control. Reguardless of the voltage, lets say it is in the 220 and up range. You take one of the 12/2 wires, white or black and hook it to the black or red on the T-stat and the white to the other one, red or black. Thats it, you are done! If the T-stat is 2-pole I am sure it is a high, Line votage T-stat. Best of Luck,
Shastalaker7
Was this helpful?
Yes
No
Popular Solutions for Fahrenheat Built-In Baseboard
Questions and Unsolved Problems for Fahrenheat Built-In Baseboard
Do you recommend Fahrenheat Built-In Baseboard Thermostat Heater?
Answer
Answer
need wiring skematic for model AR30-1, seriel # 0303511842
Answer
my thermostst has four wires they are labled off,l1,l2,cir how do you wire this up
Answer
I have a 220 Fahrenheat wall heater that I'm trying to rewire. After taking the face plate off I... (More)
Answer
thermastat needs changed need to know the easiest way to get to thermastat
Answer
i have a red and a black wire coming off of the rhermostat. and a red,white,black,and ground coming... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Heater Experts
Top Heater Repairmen
in , HI
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
