Question about Gateway 505GR PC Desktop
Vga driver old gateway w/win98, generic vga driver missing in the boot ini. pc just boots to error screen, no mouse to select changes only responds to space bar or enter + ctrl-alt-delete then loops around. Worst part, Lost the OP cd
    Scholar:
  • 135 Answers
If you know what the name of the generic vga driver that's missing, you can start the computer in MS-DOS mode (if I recall correctly, you can do that in win98), then edit the boot.ini and add it in. If not, you're out of luck and need the Windows 98 CD. Since you already own a license of Windows 98, it should be legal for you to download a copy (but I'm not a legal expert and this is not legal advice).
Posted on Jan 06, 2008
6ya staff
SOURCE:
Missing Boot INI File when starting a Dual Boot Machine , Win 7 64 bit and Win 10 64 Bit
Windows 10 is the default and will be looking for a EFI file that is probably not set up on your old hdd. Change the format of the old hdd to accommodate the new type of boot file.
Sep 29, 2015 | Computers & Internet
Tip
Removing Multiple Boot Screen
<span>If you are getting unwanted multiple boot screen<br />Then Follow these Steps.<br />1&gt; Right Click on My Computer<br />2&gt;Select Properties<br />3&gt;Select Advanced Tab<br />4&gt;Select Settings In the Startup & Recovery Section(3rd grp)<br />5&gt;Select the operating system which u want.<br />6&gt;And Click OK.<br />7&gt;Further again press the setting and click on Edit.<br />8&gt;It will open boot.ini File.<br />9&gt;Now u can delete those o/s which you don't want to be displayed.<br />Note: For deleting operating systems from boot.ini file, keep <br />it mind that you can't<br />delete that o/s which is selected by default there. Before<br />making any changes make a copy of boot.ini file</span>
on Apr 04, 2011 | Computers & Internet
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
I HAVE A GATEWAY DESKTOP COMPUTER WITH AN ERROR MESSAGE SYSTEM32\NTOSKRNL.EXE. HOW DO I FIX THIS PROBLEM?
NTOSKRNL.EXE is missing or corrupt. Issue NTOSKRNL.EXE is missing or corrupt.
Related errors
Below is a listing of the full error message that may be related to this error.
Windows NT could not start because the below file is missing or corrupt:
C:\Winnt\System32\Ntoskrnl.exe
Cause
  1. Keyboard issue
  2. Miscellaneous corruption
  3. Corrupt boot.ini file.
  4. Missing boot.ini file.
  5. Missing or corrupt ntoskrnl.exe file.
  6. Windows NT installed on a partition bigger then 7.8GB
  7. Corrupted hard disk drive or severely corrupted Windows.
Solution
Keyboard issue
This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or just disconnecting the keyboard from the computer.
Before trying any of the below recommendations it's recommend that you load the last known good configuration.
This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer.
Make sure the line pointing to the operating system and its drive and partition is properly configured in the [boot loader] and [operating systems] section.
Microsoft Windows XP users:
If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue.
Microsoft Windows NT and Windows 2000 users:
To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
  1. Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
  2. In the setup menu, type R to start the repair.
  3. When prompted for the ERD diskette insert the diskette and inspect the startup environment.
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
  1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
  2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
  3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
  4. Select the operating system you wish to fix, and then enter the administrator password.
  5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
  6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
  7. Type exit to reboot the computer.
If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below.
OS Loader v4.01
Disk I/O error status=00000001
Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
Please reinstall a copy of the above file.
If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Check the hard disk drive for any errors by running the chkdsk program. To do this follow the below steps.
  5. Once at the recovery console type chkdsk /r
  6. Once completed type exit and see if issue is resolved.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you reinstall Windows.
Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
http://www.computerhope.com/issues/ch000646.htm
Mar 02, 2012 | Gateway GT5026E PC Desktop
Missing NTLDR message, cd does not start ,have no floppy, this is a 503gr. F8 does display but does not continue to selected item, get black screen. Does a processor cause this failure?? Have original...
Your CD is not starting as it is not configured for first boot device. I am not sure on which function should be used to get to Boot Menu however you may want to try using either F2 or F12. Then its all about changing the Boot device fromHard Drive to CD. Once Changed follow the steps mentioned below,
  • Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
  • Click to select any options that are required to start the computer from the CD drive if you are prompted.
  • When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  • Press 1 (One) to select windows XP and then hit enter.
  • When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
  • At the command prompt, start typing
COPY D:\i386\ntldr C:\ (Considering that D is your CD Rom Drive)
COPY D:\i386\ntdetect C:\ (a file that may also be missing)
Then rebuild the boot configuration boot.ini file by
Attrib -H -R -S C:\boot.ini (if not found skip the next line)
DEL C:\boot.ini
BootCfg /Rebuild
Once all these steps are completed make to change the boot device to hard drive from CD rom.
Jan 07, 2011 | Gateway 503GR PC Desktop
NTLDR is missing
DEL C:\boot.ini
BootCfg /Rebuild
Nov 12, 2010 | ASUS Eee PC 4GB Notebook
Im getting the ntldr is missing message on my acer aspire 3100 that i just bought from a friend. I have no idea on how to fix this
That is the NT Loader in win98 was boot.ini regardless the OS will not continue without it. You can simply place your OS CD in set your boot order in bios to boot from cdrom. Do a manual windows repair. This will re-install the missing boot loader.
Dec 30, 2009 | Acer Aspire 3100 Notebook
In My PC Error Shows NTDLR File Is Missing,How To
Method:1
1.Make the first boot device as CD-ROM
2.Boot the system with windows(operating system cd)
3.go the first repair(r) option
4.once u got the command prompt change you directory to X:/i386
copy x;/i386/ntldr c:
copy x:/i386/ntdetect.com c:
note:x:(cdrom) drive may change
and then reboot the system.
method 2;
boot with the operating cd and go the second repair option and repair the operating system
Dec 02, 2009 | Gateway 500GR PC Desktop
NTLDR missing
I can get into the Boot First Screen but can't seem to change anything within it... These screens seems to be selectively responsive to my key presses.... I can get the bios screen up, boot order screen up but not necessarily do anything within them... e.g. I can't restart the pc using ctrl alt del when the missing NTLDR message appears.... also I have put an XP disc in and it says to press any key to BOOT from CD .... I Do so but obviously it doesn't recognise it so it gives me the missing NTLDR message again! :(
May 24, 2008 | Microsoft Windows XP Professional With...
Freezes during W98 booting.
win 98 is so outdated that the drivers for monitors is probably not compatible any more
Dec 11, 2017 | IBM NetVista A40 PC Desktop
Gateway 505GR PC Desktop Logo
125 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
