Question about Hoover F5906-900 Upright Steam Vacuum
MY HOOVER Steamvac F5906-900 does not run
I plugged in my steam vac and the motor ran for just a couple of minutes then it stopped. Nothing happens when I hit the on/off switch. I tried different outlets with no changes.
  • debbish Jan 07, 2008
    The cord looks fine and there was no indication the motor was going bad. How to test?
    President:
  • 1,673 Answers
There is a switch, but could be a bad cord, or the motor went bad.
Posted on Jan 06, 2008
  • Lauren Junge
    Lauren Junge Jan 07, 2008
    You would need a meter, so you can check for continuity on the cord. The cord has 2 leads, so you test to see if one of the leads is open. If one lead is open, replace the cord. Same with the motor, unhook the power leads and see if you get a low ready or not. If you take the motor out, does the fan turn or is it froze up. If it is, replace the motor. If you check the swith, turned off, it should read open, on it will read alittle or continutity.
Hoover steam vac spin vac making loud noise sparks flying
The only source for electrical sparks is the motor so it must be checked. Bad motor brushes or a broken wire are possible causes. Do not use in this condition.
Aug 29, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac smoking
Your problem sounds electrical in nature. I would take it in for evaluation / estimate of service.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Apr 22, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
I have a Hoover Steam Vac. Even though I don't
There in the trigger assembly is a release button that might be broken.
Nov 28, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
The steam vac stopped working while in use and
If the cleaner will not turn on at all, you could have one of several problems:
(1) Bad foot switch
(2) Bad power cord, or
(3) Motor failure.
The unit would need disassembled and tested with a continuity meter to determine the part that failed.
Oct 25, 2009 | Hoover SteamVac F5914-900 SpinScrub...
How do I clean the nozzle of my Hoover steam vac Jr?
No, this assembly can only be rinsed under running water.
Sep 29, 2009 | Hoover F5411 SteamVac Jr. Canister Vacuum
Hoover steam vac
http://www.hoover.com/pdfs/manuals/F5914900.pdf sounds like it needs to be cleaned out above are directions on how to do so and other cleaning options to help your machine run better
Godbless
Jun 15, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Loss of suction
Make sure the recovery tank lid is on correctly. Also make sure the float on the receovery tank lid is down.
May 24, 2009 | Hoover F7431-900 SteamVac Vacuum
Problems with the Hoover Steam vac Heated carpet cleaner
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter.
Nov 18, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover F5906-900 Upright Steam Vacuum Logo
267 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
