Question about Canon PowerShot A520 Digital Camera
Jammed Lense I pushed the lense closed by mistake when the powert was on. The lense now won't extend out when power turned back on.
  • heather77 Jan 09, 2008
    Camera turns on Screen blank and lense won't come out
  • Canon Master
  • 4,738 Answers
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jan 08, 2008
I own a sony cybershot dsc w35 when i switch on the screen displays "turn the power off and on again" help?
Hi. I had exactly the same problem with my Sony Cyber-Shot DSC-W7. The problem started after while lense was fully open, the battery became 100% empty. I did not have access to new batteries and did not have my charger with me so I put the camera on my car seat and went home. After charging the batteries, I turned the camera Off and the lense retracted 100%. Later on I tried to transfer some pictures to my PC. After connecting the camera to my PC with the dial in the P position and lense fully open I turned the dial to play in order to transfer photos. After transferring the pictures, I turned the camera off and disconnected from the computer.
I turn the camera on to take new pictures next day, The lense would go up, and and turn with lense fully open. It would never close. The screen was black with a message "Turn the camera on and off again". I tried 30 times or more and the same thing would happen again.
Here is what I did to fix my camera and it has been working normally since then.
1- I cleaned around the outside of the lense with lent free cloth
2- I used dust OFF to get raid of the remaining small dust particles from around the lense.
3- While turning the camera off, I pushed (down, up and turn) the lense in (NOT TOO Hard) by my hand. If you push the lense too hard, you may damage the mechanicall moving parts of the lense.
4- After a few tries, the lense retracted 90% +. I then pushed the lense a little harder all the way in, the way it normall retracts. The lense cover also closed 100%.
5- I turned the Camera on and off a few times. It was opening and closing exactly the way it used to. My Cybershot has been working okay since then.
I read a lot and here is what cause my lense to malfunction.
While lense was fully open and battery died, some small particles got on the lense and prevented lense from fully opening or closing.
In summery: two things could have caused your camera lense to malfunction.
1- if you had dropped your camera hard, some mechanical parts may have got damaged or dislocated. In this case you have to open the lense and replace the damaged part, clean and put it back on the camera. This is too risky for most ordinary people. You would most likely make it WORST.
2- If you did not drop it, most likly, some how some small dust particles got on the outside of the lense and they prevent the lense or the lense cover from fully opening and closing. If this is your case, please follow exactly what I did and your camera would be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 25, 2009 | Sony Cameras
Turn the power off and on again
Jun 25, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Lens keep extended in an out
Jun 25, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
My Sony Cyber-Shot DSC-W55 camera does not turn on properly. When I press the gallery button, everything runs smoothly. When I press the on button, the lens opens and closes several times, making a little...
Jun 25, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Jammed lens
When you turn it off, does the lense go up and down. If yes good news. while turning the camera off press on the lense very softly (up and down motion) until the lense retracts 100% or almost 100%. you may have to try a few times. if almost 100% retracted, push the lense a little harder in, untill it retracts all the way in. Turn it back on, it should work now. If you do not keep your lense clean you get that problem. After you droped it, some mechanical part on the lense may have broken or dislocated. In this case you have to open the lense inspect the parts, clean them and puth them back together.
Jun 08, 2009 | Polaroid i830 Digital Camera
Canon G7 lense does not extend fully but it is NOT e18
Maybe lens needs adjustment. The info on this page may help. Copy and paste this link for more info.
http://www.fixya.com/PostAnswer.aspx?thid=1841738&prdid=447928&ctgid=67
Mar 22, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Battery died while lense extended and now will not power up.
Some of these cameras that have a lens that extends use gears to extend the lens. The gears can strip or get clogged with fine debris and jam the lens. Usung good quality rechargable batteries NOT ALKALINE will usualy have the power to drive the lens.
Ask yourself, how many cycles do you have on the pack? could the pack be weak and not power the camera fully?
Have you tried pushing firmly in on the battery while you power it up? If the camera will not power on with the door open, try and fold a small trip of paper and sit it between the battery and the door. This might push in on the battery enough to better the connection and solve the issue.
If the battery is fine then you may have a lens problem. The lenses can be jammed easy, dropped or an impact when extended is all it takes.
Jan 26, 2009 | Sony Cameras
A730 Lense extended
yeah I got screwed buying a samsung camera too.
Samsung screwed me out of a rebate on a computer monitor before too.
I will never buy another samsung product!!!!
May 26, 2008 | Samsung Digimax S730 Digital Camera
Cameras lense open, camera off, when turned on it bleeps and turns itself off
i have exactly the same problem with exactly the same camera. It happened to me once before but by 'fiddling' with it, it seemed to catch back in place and turn on again. but this time it wont work. seems like a design fauly from samsung?
Nov 08, 2006 | Samsung Digimax V800 Digital Camera
Canon PowerShot A520 Digital Camera Logo
75 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
