Back to:
Tags:
Kitchen Cooktops
Generic problem for all Kitchen Cooktops
Jennair gas cooktop (by 2 users)
posted by londowell on Jan 06, 2008
My ignitors keep firing after the gas is turned off... I steamed a dungenes crab last night and some water boiled over... I figured that some water went where it shouldn't go and in the morning all would be fine. Nope... The product manual (on-line) does not speak to this problem.
Any help please?
Comment by londowell, posted on Jan 07, 2008
Thank you for your comments! I'll wait till morning and then use the hair-dryer...
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Sep 15, 2008
One of my ignitors keeps on clicking even after it is lit. This is not a problem with the other 3. Have tried drying, cleaning and moving disk on top of the burner element but still no joy. Any ideas?
Best Solution
posted on Jan 06, 2008
Helpful (85)
textonor
Rank:Guru Guru
Rating: 89%, 96 votes
Sounds like you got water into the ignitor switches on under the knobs. Sometimes it takes 48 hours for this to dry out. Or you can pull the knobs and use a hair dryer on to dry out the switches. Personally I just advise pulling the plug and wait. This is a common issue with gas cooktops and can also happen with liberal use of cleaning products sprayed in the know area.
Rating Locked! (?) londowell has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Jennair gas cooktop:
I don't want to Accept this solution
Can you Help with these Kitchen Cooktops problems?
Kitchen Cooktops
We have a ceramic hob by Shott Ceran touch control but the...
Kenmore 42800 Stainless SteelCooktop
seems as though sears does not know what these codes are,...
Kitchen Cooktops
None of my burners are sparking at all. I have a new...
Kitchen Cooktops
like the vent button and the convect and now the set up...
Kitchen Cooktops
Cooktop indicator light stays on all the time. Only 4...
Loading problems.
Repair Service
Find Kitchen Cooktop Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
