How do I make my new Belkin "N" Router work with my older netbook that worked properly with a G Router and it can't view streaming videos now. Before my old "G" Router broke I could watch streaming video on my older laptop but now it doesn't seem to have enough power to view the streaming videos since I connected a new Belkin "N" Router to my modem. Is there a setting that allows the laptop to view streaming videos with the new "N" Router?
An N router supports b & g as well, but may not be so very effective with the "g" signal. You might try to put a higher gain antenna on the router's wireless, and aiming it towards your laptop.
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas,...
(More)
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas, access points)?
Stability and reliability are also critical
We use a comcast cable modem
Must support mixed environment - 2 Macs connecting wirelessly, 2 PCs (1 with a wired connection)
We all want to be able to share a printer (which will connect to router with a wired connection)
Network attached storage, media streaming - I'm not worried about these now, looking for basic connectivity. Though would be great if I could grow into this in the future...
My problem is that my wireless network is not detected by my pc using an TEW-624UB Wireless N USB...
(More)
My problem is that my wireless network is not detected by my pc using an TEW-624UB Wireless N USB Dongle, It does detect other SSID's in my area. My ssid is not set to hide. And I can connect to my wifi network via my ps3 and also 2 laptops which have built in wifi adapters. I have tried plugging the TEW-624UB usb adapter to the laptop and checking if it displays my wifi ssid. but it is the same. It displays evey other network in my vicinity except my own. I figured it might be a problem with the usb wifi adapter and have since tried it with a Dlink DWA-110, but with the same results both on my computer and laptop it detects other networks accept my own. Mind you my PS3 and the Laptops using their built in wifi adapters is able to connect to my home wifi without any problems. I am using WPA-WPA2 as security and most of the other settings as default. I've tried changin the channel from 1 to 11 without any results. also turing off the wifi security does nothing.
How do you open ports ona westell versalink 327w? I play World of Warcraft and it wont let me...
(More)
How do you open ports ona westell versalink 327w? I play World of Warcraft and it wont let me connect because the right ports aren't open. Its at my gf house so I didn't set it up in the first place.
