Suddenly my B60 is only putting out about 1/2 normal amt. coffee. always use medium cup option - only filling less than half normal size mug using refillable kcup, barista specifically ground for keurig using grind "7". what could be problems?
It starts to brew, then only dispenses a little amount of coffee. I have checked the exit needle and...
(More)
It starts to brew, then only dispenses a little amount of coffee. I have checked the exit needle and have throughly rinsed out the k-cup holder. Usually it takes a couple of seconds before it starts dispensing, but it starts dripping immediately when this happens. Sometimes I can turn it off and back on and it will work but not always.
I use 2 Keurig B40's for my display and I need to replace my broken water compartments... please...
(More)
I use 2 Keurig B40's for my display and I need to replace my broken water compartments... please advise me of where I can purchase 2 of the water compartmants....
1 yr old b60 model all of a sudden will not brew after it has drawn extra water from the resevoir...
(More)
1 yr old b60 model all of a sudden will not brew after it has drawn extra water from the resevoir and therefore sits in a stuck idle condition. Have taken all user accessable parts meant to be cleaned apart, and washed thoroughly as per Keurig's instructions. After placing all parts back in order problem persists. The only way to clear the frozen display is to unplug and plug unit back in, however the next time you try to brew problem reoccurs.
