Kenmore 62602 Electric Dryer
Problem for Kenmore 62602 Electric Dryer
My kenmore HD60 series dryer drum does not turn.
By jahoehne on Nov 09, 2009
my kenmore HD60 series dryer does not turn. THE BELT IS INTACT, I can smell the heating element getting hot, I replaced the push button "on" switch. The drum does not turn. What is wrong with this dryer?
Solution #1
posted on Nov 10, 2009
Not Rated)
hunter19_46m
Rank: Guru  Kenmore Washers & Dryers  Expert
Rating: 91%, 256 votes
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Was this helpful?
Yes
No
Popular Solutions for Kenmore 62602 Electric Dryer
Questions and Unsolved Problems for Kenmore 62602 Electric Dryer
Do you recommend Kenmore 62602 Electric Dryer?
Answer
Answer
is there an adjustment on the stackable kenmore dryer 4179172000 belt pully when replacing belt?... (More)
Answer
my kenmore ultra fabric care dryer heats up but will not spin...HELP
Answer
My dryer is showing an F70 code and is not running
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dryers Experts
Top Washer & Dryer Repairmen
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
