I would remove the lid from the compressor and verify the connections are all in place and not rusted or melted, More then likely your capacitor has gone bad for your compressor, unless you have the proper testing meter then Id recommendreplacing the capacitor, and just check for any loose or burnt wires.
Take it with you to a local Hvac supplier to get a proper replacement.
My RV roof top air conditioner has no power going throw the circuit board needing to replace the...
(More)
My RV roof top air conditioner has no power going throw the circuit board needing to replace the circuit board .
model 59516331G9 on the comfort control center digital screen will show temp set for a short time...
(More)
model 59516331G9 on the comfort control center digital screen will show temp set for a short time the show E-4 this goes back and forth fan will come and go off. The controls come on for furnace or coll but still show the same notes
a/c and furnace wont work.I have a duo therm, model #59516.531 on my toyhauler with a 3107541.009...
(More)
a/c and furnace wont work.I have a duo therm, model #59516.531 on my toyhauler with a 3107541.009 thermistat... The a/c-furnace switch when selected does nothing..cant even hear the relay board clicking.. but the fan works fine..High and low. I have checked the fuse in the relay box and circuit breakers on panel and on onan genny.. dont know of any more?
I have removed the interior bracket and outside I have removed the shroud. What is next? This is a...
(More)
I have removed the interior bracket and outside I have removed the shroud. What is next? This is a Duo therm roof top Penguin model
