When the bake igniter becomes weak or burns out, your oven will not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve will not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat -- defective selector switch -- defective gas safety valve -- defective gas valve coils
I want to buy a compact, simple microwave oven for warming up food, with a tray that turns. I prefer...
(More)
I want to buy a compact, simple microwave oven for warming up food, with a tray that turns. I prefer the mechanical kind, because it's simpler, but I can handle a digital model. I've seen an AKAI model mw-jn0717mp2 which warms up the food quickly. It seems to be an older model. What is a newer model of AKAI? Or any other brand that has enough wattage to warm up the food quickly and evenly?
I have a candy fan assisted oven it's blowing out cold air and not getting hot what is wrong with...
(More)
I have a candy fan assisted oven it's blowing out cold air and not getting hot what is wrong with it.
