I could be wrong, but you do have a chemical problem. Be it PH or chlor. After 35 years in the business I have seen one heat exchanger that came from the factory bad, and none that wore out with out chemical help. If you don't have a PH problem then you have a chlor problem. This is most often at an inline chlorinator that is mounted to close to the heater and lets chlor gas back up into the heater when off or in front of the heater so all the feed is going straight to the heater. This is the more lodgical of the two as fast as your wearing the exchangers out. Green plaster is a big simpton of this as the copper from the heater has to go somewhere. This can be fixed as easy as a chloriene floater or replumb to move chlorinator. Good luck
I want to buy my husband a pool. What would you recommend? do I need any kind of special pumps?...
(More)
I want to buy my husband a pool. What would you recommend? do I need any kind of special pumps? also, I want the pool to be worm
Pelonis Holmes two different oil filled radiator style heaters. lights and thermostats work but NO...
(More)
Pelonis Holmes two different oil filled radiator style heaters. lights and thermostats work but NO HEAT any ideas? Thank you Terry tleff@comcast.net They are over 2 years old..do they just wear out?
The Blower/heat is not working but the flames are lite. Cleaned the bottom of the unit which had a...
(More)
The Blower/heat is not working but the flames are lite. Cleaned the bottom of the unit which had a build up of dust
I have a Jacuzzi spa that has a "FL" on the readout. I am not sure what type of control it...
(More)
I have a Jacuzzi spa that has a "FL" on the readout. I am not sure what type of control it is but there is a picture of a thermometer on the right side and the pump control to the left. Can you tell me what the FL means. If I cycle the power it appears the set temp is 100 and the water temp is 87. The FL returns after about 15 seconds.
