Electric Wall Heater Sparking
I have an electric wall heater in my condo that's worked fine for years. But the first time I turned the thermostat on this Winter, a bunch of blue sparks lit up in the heater itself. Of course I turned it off. I tried it a second time and it happened again. Any ideas what could be causing this?
  • jamiejette Jan 06, 2008
    Thanks that's good to hear. I'll check it out!
You could have a loose wire or maybe some of your wires are touching, same thing happend to me and when i opened it up all i had to do was tape up the wires and it worked again
Posted on Jan 06, 2008
How do i wire a 240volt hydronic base board heater and thermastat
I need a control knob for my Marley electric wall heater model#fzl3004b
Dec 17, 2012 | Marley Electric Hydronic Baseboard Heater,...
I need an instruction manual for a comfy air wall heater
how do you ste up the comryfair slimline panel wall heater
Jan 08, 2012 | Heating & Cooling
I need to wire a remote thermostat to my electric wall heater in the bathroom. Not sure if I run the wire from the panel to the heater first or to the remote thermostat then the heater.
Run the wire to the thermostat then to the heater
Jun 21, 2011 | Heating & Cooling
I'm puzzled by what may be causing low heat output from a Markel wall-mounted 240V electric heater, new from around 1984; cannot find model number. I'm not sure of the wattage rating. The heater element...
your element may have metered out but still may not getting as hot as it used too found this on my hot water cylinder, the hot water was only warm not hot like it should be so pulled out it meterwd fine but when i placed a new one in the cylinder and let the water heat up it was a lot hotter than it had been and now i can't get out of the shower but it was the element not heating as it should have and thats just old age i bet i don't run as hot when im old and it was nearly thirty year old heater, if it was new from 1984 it sounds like its had a full life i don't really expect heater to last more than thirty years well really more than twenty years anyway and a heater from the eighties couldn't have never been that efficient and **** a bit of power too i'd upgrade to at least a 2000 model heater you'll actually save money by buying a newer one!
Nov 19, 2010 | TPI H3327TDRP Markel Electric Wall Mounted...
I have a Dayton Electric Wall Heater which I bought last year. I tried to turn it on but it didn't work. The model is 3UG55D. I checked the power which was fine. Then I cleaned it from the inside and it...
Ohm out the element...make sure that is good...
also ohm out the thermostat to check that out...
basically just follow the power to see why it is not
making the element heat....
You can get parts from
Sep 14, 2010 | Dayton Electric Heater
Electric Hydronic Baseboard Heater, 240 Volt: WHEN I TURNED ON MY ELECTRIC BASEBOARD HEATER THER...
My PLF504 detonated this morning (11-25-2010). It worked fine for two years then BANG. Room was lit by flame coming from center (left to right) of unit. I wrote Marley asking them to honor the 10 year heater element warranty. Also, no burnt wires at thermostat connection, no dust bunnies on the fins. Source of fire was the fluid filled encapsulated heater core. Thank God, circuit breaker tripped and wall was tiled.
May 17, 2010 | Fahrenheat Electric Hydronic Baseboard...
Electric baseboard heater worked last week. but when I
The wall thermostat will click even if there is no power. You will need an electric metere to trace down the problem. May be a bad breaker, bad limit switch or the element could have went bad. You need to follow the electric and see what is interupting the flow.
Nov 12, 2009 | Fahrenheat FBE15002 Baseboard Heater
Williams wall furnace, top vent.
I've replaced a Williams wall gas heater non-electric. The thermostat is connected right and mounted on the wall. But, there's a thick black copper wire on the side of the furnace tagged thermostat. I don't know what to do with it? Where do you connect this wire? When it touches the top screw of the three screws running vertically(where the other wires are connected). The burner lights up and stays on, even if you play with the wall thermostat. Touching the other two screws doesn't do anything. Now, the manual talks about connecting it to the venting wires? Extra wires coming from the top or maybe somewhere else in the wall? I've left it connected to the first screw, ran the heater. But, it never turns off? Any suggestions? Thanks
Dec 13, 2007 | Heating & Cooling
Fahrenheat wall unit
your on-off switch is faulty - need to replace it.
Dec 07, 2007 | Fahrenheat ECP1524 Wall Mounted Panel...
Heating & Cooling Logo
109 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
