Question about Hoover U8145-900 Savvy Bagless Upright Cyclonic Vacuum
Hoover savvy changeing belt
I think changing a belt should be easy but say no more . How would you change the belt on the roller. We can not get the cover off to attach the end to the motor
Thanks,
Mark L.
    President:
  • 1,673 Answers
There some screws on the bottom to take off, then turn vac upright, under the round Hoover logo sticker is another screw. It is just a sticker, so will peel off. You can work the belt onto the motor pulley, or unscrew the motor, put the belt on the pulley, then reinstall the screws to hold down the motor.
Posted on Jan 06, 2008
I long for the days when things were made for easy repair for an average joe, Belt replacement for my Hoover is rediculously time consuming. I won't buy another!
Posted on Jun 06, 2008
Thanks for the idea of taking the logo sticker off. I never would have throught there would be a screw under there. I still however had to loosen the plastic piece that holds the pulley and then when there was more give in the plastic I had to pry the pulley out because there was no other way to get the belt around the pulley. I haven't put it back together yet because I haven't recieved the belt that I ordered online. I have by the way had to replace the switch assembly. Which is apparently a design flaw.
Posted on Apr 12, 2008
Hoover savvy upright has no suction on carpet what's wrong?
9 times out of ten this is the response when you have a broken belt. The suction is the same but nothing gets picked up because there is no brush turning. Turn your machine off and see if you can turn the roller easily by hand. If you can you will need to change the vacuum belt.
If you are in Australia and need vacuum parts check out www.vacuumspot.com.au
May 12, 2012 | Hoover Vacuums
How to change belt on hoover savvy vacuum
How do I change the smaller brush belt on a Hoover Windtunnel Cyclonic?
Jan 11, 2010 | Hoover U8145-900 Savvy Bagless Upright...
How do you change the Hoover wind tunnel belts?
If you turn the vacuum over there will be (4) screws that hold on the base cover for the roller brush. Remove the screws and the cover and you can get to the belt(s). You can get replacement belts here:
Hoover Windtunnel Belts
Nov 18, 2009 | Hoover Company Wind Tunnel U53019 Upright...
Roller bars on bottom not rolling
The belt has probably broken. Hoover says that the belt on this model should last the life of the vacuum, but that is rarely the case. They do wear and break. Changing the belt is simple and the belts aren't to much. You can get a replacement here:
Savvy Replacement Belts
Oct 30, 2009 | Hoover U8145-900 Savvy Bagless Upright...
Change belt on a hoover tempo
Remove the cover that covers the roller brush, (four screws) and remove
the roller brush and replace belt, it goes between the motor shaft and the roller brush. Replace the cover and that should do it.
Tom
Aug 04, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
I have a Hoover WindTunnel, Self-propelled model, and it was working great until I ran over a portion of the cord, then it started making a bad noise and I noticed the roller is not moving consistently...I...
The V belt usually wears down first. Remove the roller and belt to visually check for wear and belt material in the roller pulley. I would change the flat belt as well. Also, replace the cord if any wires are exposed
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Mar 08, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
I have a Hoover TurboPOWER 7300 Windtunnel V2-belt change
1. Remove the 4 screws holding the bottom plate.
2. remove roller and old belt
3. install new belt on motor spindle first and then on roller.
4. pull roller, stretching belt, set into roller cavity.
5. turn roller by hand to center belt.
6. reinstall bottom plate.& screws
Feb 26, 2009 | Hoover U5444-900 5100 Wind Tunnel 15 Inch...
Lost instructions,need to change belt
The customer operation manual can be downloaded from the hoover web site hoover.com
the bottom cover comes off with 4 screws. install the belt on the motor, then roller, stretch to install roller into cavity. replace cover.
Feb 24, 2009 | Hoover U5753-900 WindTunnel Bagless...
Hoover US8174-900 Savvy Bagless
It uses a cogged belt, turn it over, remove the bottom plate, remove the other screws from the bottom, turn vac back over and remove the Hoover emblem, there is a screw there to remove and the top comes off, then you can get to and replace the belt.
May 26, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Belt change on savvy upright
Take off the bottom plate, also remove the screwsfrom the bottom to remove the top cover, also there is a screw under the Hoover emblem on the top cover, with these removed you can get to to brush roll and belt.
May 11, 2008 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Hoover U8145-900 Savvy Bagless Upright Cyclonic Vacuum Logo
196 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
