Question about Samsung LN-S4051D 40 in. LCD Television
40 inch lcd blue line vertical
My tv just got a blue line going down the right side 3 inches in the screen :(
  • 7 more comments
  • gegajames Jan 06, 2008
    ty i will try that :)
  • Anonymous Feb 09, 2008
    Having the same EXACT problem on my Samsung LN-S2651D. Samsung gave me a few things to try, then disappeared from further assistance. Wonder if there's a known defect?
  • Anonymous Apr 30, 2008
    Vertical blue lines 5+ inches long appearing on both right and left side of Samsung 40" screen. This tv is only just over a year old. What a piece of junk.
  • Anonymous Jul 30, 2008
    Same problem: New 40" Samsung LCD. Have 3 " blue line (vertical). Samsung sending person out after a long call to tech support. Will post if learn anything
  • Anonymous Mar 14, 2014
    three inch vertical blue line running don left side of tv
  • Anonymous Mar 16, 2014
    3" vertical white line going down the right side of my plasma tv
    different colored lines on right side of 50 inch plasma tv
  • Anonymous Mar 21, 2014
    4 inch bar on right side of screen about 6 inches from the edge with color lines flashing on and off
  • Anonymous Mar 26, 2014
    pix is good other than vert lines 1 inch apart across screen top to bottom
  • 579 Answers
The display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Hope ya fix it!
Posted on Jan 06, 2008
    New Friend:
Got two blue lines going down the left side of tv screen
Posted on Nov 25, 2012
Have just purchased Samsung LA32R81BD have thin blue vertical line a third into the left hand side of the screen. A pity no support on a sunday or public holiday! Tried the squeeze theory without joy. Will attempt swap and see what excuses the dealer has? Thanx for advice fixya!
Posted on May 03, 2008
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 210 Answers
SOURCE: My SOny Bravia 40 inch LCD TV has a vertical line
It could be 1 of 4 things:
1. One of the ribbon cables has worked itself loose (Simple Fix)
2. One of the assembly boards maybe faulty
3. The driver board which feeds the panel maybe faulty
4. The panel is faulty
The driver board in the UK costs approx £70 and approx £35-70 to fit it if this is the fault.
All other parts are between £80-160 and approx £35-70 to fit it if this is the fault.
The panel will cost approx 50-75% of what the TV was worth when you bought it - "Repair versus Replacement"
Thanks
Posted on Oct 01, 2009
I have vertical black lines in my Samsung s42ax-yb09 plasma TV. one 3 inch band down the right side and a 9 inch band down the middle a foot from the right of the screen and 15.5 inches from the left
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 29, 2016 | Samsung Televison & Video
Why my t.v screen is one inch less from down side?
Vertical scan output section circuit fault.
Visit this site to get more details.
Feb 19, 2015 | Televison & Video
How do I fix my Sharp tv from right side to center there's a half inch black line 9 inches down from top on screen and it changes color depending on background and UNDER the line the image is blurry a
If this is done with every input of your tv and also with tv channels this means a bad circuitboard .You can find on ebay one and mod it yourself. Its not such a difficult thing.
Nov 26, 2014 | Sharp LC40E67UN TV
Sanyo flat screen tv about 2 yrs old has thin colored horizontal lines down the right side
Nothing you can do about that...get used to it or change the TV.
It's a defect in the panel that can't be reliably fixed.
Feb 15, 2013 | Sanyo DP46848 LCD TV
I have black line down right side of 42 inch hitachi lcd tv screen
You have a CCFL lamp that is failing in the panel, time for a new TV
Jan 22, 2018 | Hitachi Televison & Video
Thanks
Oct 01, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Red blue and green not lined up
56 inch panasonic tv has blue yellow lines running up and down on right side
Apr 09, 2009 | Panasonic PT-56WXF95 56" Rear Projection...
Screen fades to blue.
The Blue SCREEN setting is too high. These adjustments are located inside the TV behind the front panel. There are two screws behind covers and then a wooden panel to remove to access the adjustments. The leftmost set are for BLUE, the middle are GREEN, and the right are RED. The top row are FOCUS and the bottom are SCREEN. Focus will focus/unfocus the tube and Screen will adjust the power of that tube (there are 3 tubes, one for each color). If Screen is adjusted too high, horizontal lines will appear (my TV had red lines, but I played around with the knobs and saw that it could happen on any of the colors). Additionally, if SCREEN is set even higher than that, the tube could go so high that it turns the whole screen that color (in your case, blue). If this happens the TV will shut down, probably due to either overheating or overvolting. To fix this issue, turn the appropriate SCREEN dial down until the lines go away. In your case, you want to turn the lower left dial down. Don't turn it too far down, if you turn it more than necessary the TV can give you an AKB error (noted by the STANDBY light flashing a sequence of 5 blinks).
Apr 02, 2009 | Sony KP-57WS500 57" Rear Projection...
Samsung LN-S4051D 40 in. LCD Television Logo
1,599 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
