Acer AL1711 LCD Monitor goes repeatedly black after bootup after just a few secs picture and has to be turned on & off at least 6 times thereafter with picture staying only 2 secs each time until picture stays permanently. Same thing when connected to a different computer but had to use the same monitor cable each time.
cpburn, It's BROKEN!!! SHUT IT OFF AND LEAVE IT OFF!!! The "switch-mode-power-supply" has DETECTED a fault and then goes into full or partial SHUTDOWN to save itself from a catastrophic, nonrecoverable failure. eg. sparks, smoke, fire. The good news is you stated "picture staying only 2secs" !!! It can be fixed! Just how you do it is the question only you can answer. If you know how to replace components on a circuit board (unsolder&solder) you might do it for less than $12 in parts. To understand exactly what is involved I suggest a visit to www.ccl-la.com/badcaps.htm run by another guy on fixya with nickname "buddymc"! He's GOOD! If "do it yourself" is not your thing, then here are your options: Acer refurb swapout. ??? Contract to local TV/Monitor shop.?? Contract to a distant Repair shop.??? But before doing any of the above try YOUTUBE and search out and view some of the longer (6-12min) vid clips of "LCD monitor disassembly""Lcd monitor repair". If you require further assistance I can be accessed through [removed by staff] or on fixya. I'm 12fixlouie If this response was of some help please rate on fixya. Bye fo now.
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
I reinstalled, tried on another computer & changed cables but problem getting worse.Looks like ur right Monitor kaput,will check out ur links & Thanks
" - cpburn
Inherited a 226bw that had a bad power supply. Got a new one and replaced it. The power button...
(More)
Inherited a 226bw that had a bad power supply. Got a new one and replaced it. The power button lights up on the front of the panel but the screen wont light any suggestions?
aoc 22 inch monitor gos off when live tv or movies. message comes on ,said no single. can still hear...
(More)
aoc 22 inch monitor gos off when live tv or movies. message comes on ,said no single. can still hear program. lee g.
