Need a replacement cross blade for a grind-o-mat hand operated grinder. Could not find a model number and I think it is a rival. shaft for blade is approximately 3/8". Please advise if a replacement blade is available
The feed screw is not tight in the grinding chute and the blade is not engage. Shaft does not...
(More)
The feed screw is not tight in the grinding chute and the blade is not engage. Shaft does not protrude from the cutter disk. Someone told me there should be metal washers inserted between the grinding chute and the screw. Is this true?
