Maxent P420142X1 - not showing image when connected through AV or Component input. Sound comes in for a second when input is selected or sound fixed/variable is changed in the OSD-menu. Screen stays always blue, except when cable box (OPtmum) or DVD(philips) player are connected when the screen is green. Audio input works well on RGB and DVI but only after changing sound in the OSD-menu (fixed-variable, doesn't matter as long as it is switched from one to another, sounds comes in but if monitor is turned off or input is changed, sounds goes off and one has to go back to select on menu) Annoying! Any hint?
what type of surround sound speakers are compatible for an hitachi 42LDF30U A tv? what would you...
(More)
what type of surround sound speakers are compatible for an hitachi 42LDF30U A tv? what would you recommend.
! have a panasonic th-50phw3 plasma when you turn it on it tries to come on but shuts down then red...
(More)
! have a panasonic th-50phw3 plasma when you turn it on it tries to come on but shuts down then red light blinks three times then steady then 3 times again then steady over and over. Easy fix or just get another tv.
I have an Insignia 32" TV and a black box appears in the center of the viewing screen with Dos...
(More)
I have an Insignia 32" TV and a black box appears in the center of the viewing screen with Dos codes printing across the screen
tv
When I connect my Laptop to a Philips lcd tv via HDMI cable, the video is ok but the sound is...
(More)
When I connect my Laptop to a Philips lcd tv via HDMI cable, the video is ok but the sound is missing.
