John Deere 4020 Gas & Diesel Tractor Radiator
Problem for John Deere 4020 Gas & Diesel Tractor Radiator
4120 eletc.hydrostat drive will not move forward
By deerebill on Nov 09, 2009
4120 eletc.hydrostat drive will not move forward or back ward.was running fine turned it off for a moment then back on and would not move.
Solution #1
posted on Nov 10, 2009
Not Rated)
n2vrh
Rank: Wiz
Rating: 94%, 5 votes
It sound like either the hydraulic filter is plugged or one of the safty switches have come undone, either by a break in the wire or a connector fauling off, anouther area to look is at all the linkage to make sure nothings has become dis-connected.finally check to make sure the belt driving the hydralic unit is within factory specs and tight enough. Hope this Helps Don
Was this helpful?
Yes
No
Popular Solutions for John Deere 4020 Gas & Diesel
Questions and Unsolved Problems for John Deere 4020 Gas & Diesel
Do you recommend John Deere 4020 Gas & Diesel Tractor Radiator?
Answer
Answer
i have a 1967 4020 it is boging bad and smoking when u loosen return line to injection pump it runs... (More)
Answer
trans-hydralic leak under 1965 JD 4010 diesel rearend where the drawbar attaches to rearend around... (More)
Answer
I replaced the top bushing and o-ring on the plunger of the PTO engagement valve which is located in... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For John Deere 4020 Gas & Diesel...:
Top Riding Mower and Gar... Experts
Rank: Guru Guru
Solutions: 1220
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Riding Mower and Gar... Experts
Top Garden & Power Tool Repair
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
